Go to Post Don't just build a robot; build up your community. - Pat Arnold [more]
Unread 02-24-2010, 12:51 AM
RMR: TeamPlasma's Avatar
RMR: TeamPlasma RMR: TeamPlasma is offline
Programer
AKA: Michael Przeslica
FRC #2403 (Red Mountain RObotics, Team Plasma)
Rookie Year: 2007
RMR: TeamPlasma is an unknown quantity at this point
pic: 2403 Side View No Bumpers
Greetings from team 2403 "Team Plasma"
Here is our 'bot!
Drive: 2 CIMs on each side, 6 wheel drive with 4x 8" dualie omni wheels and 2x plaction wheels, rocking suspension on the back.
Chassis: the standard 2010 c-base with gearboxed mounted on top, battery underneath, and electronics at the back, hinged lexan covering the electronics and hinged diamond plate covering the kicker and battery access.
Kicker: spinning steel turbine powered by a CIM and a belt. Pops the ball over one bump
Ball incursion: sloped top flush with the top of the bumpers at the front and back, front and rear have a steel bar.
Strategy: push around all the robots with holomonic wheels and 2 motor drive ; )
Best Feature: driving over the bump! It drives very smoothly over it no matter how fast we go!
P.s. we need some help naming it! I was thinking "one steel wonder" because it seems the most dangerous component of all of our robots havs always been made of angle or tube steel!
p.p.s. More pictures and such at our site: http://www.wix.com/teamplasma/rm-robotics
Last edited by RMR: TeamPlasma : 02-24-2010 at 01:31 AM. Reason: add links for more photos
Unread 02-24-2010, 12:55 AM
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Coach
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Re: pic: 2403 Side View No Bumpers
Coolio. I like the diamondplate. Hardcore. I expect you can traverse the bump in your sleep.
Cold Fusion's 10th Season
Unread 02-24-2010, 01:41 AM
Programer
Rookie Year: 2007
Exactly! At the beginning of the build season, we were like "well, lets make a plastic electronics board instead of a wooden one this time" and then we found that diamond plate left over from last year...at least aluminum is non-conductive ; )
Unread 02-24-2010, 05:55 AM
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Except that it is conductive...
Shouldn't matter as long as you have your cRIO and camera (if you're using it) mounted with non-conductive bolts+spacers.
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 02-24-2010, 09:15 AM
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
Team Role: Mechanical
the man is on a distinguished road
Yes aluminum is conductive thats why we dont dump aluminum shavings on the crio
Every day is a new adventure!!!
Unread 02-24-2010, 09:20 AM
Programer
Rookie Year: 2007
Red face Re: pic: 2403 Side View No Bumpers
Oh yeah...I apologize for the misinformation...I posted this at like 1 am last night and I also see all the misspellings now!
Anyways, yeah, each electronics component is separated from the aluminum by foam rubber. Thanks for pointing it out!
Unread 02-24-2010, 09:27 AM
the man's Avatar
AKA: Jacob Overla
FRC #4004
Good, I wouldent want to see any fire balls transvering a bump
pic: 1346 Side View 2009 dtengineering Extra Discussion 8 02-05-2009 03:23 PM
pic: Drivetrain Side View AustinSchuh Extra Discussion 23 12-30-2006 03:41 AM
pic: Team 226 side view CD47-Bot Robot Showcase 8 02-25-2004 04:25 PM
pic: Team 271's Side View CD47-Bot Robot Showcase 1 03-17-2003 06:48 PM
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 03:26 PM
