Go to Post I do this stuff because...well first inspired me to become me. I now understand who i am better and what i want to do. - Marygrace [more]
Unread 02-24-2010, 01:43 PM
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Exclamation Watchdog Not Fed!
Although this might seem like those classic "Watchdog" problems, this problem is special...
We use "Iterative Robot" system to program out robot, and we implemented things like solenoids, compressors, and camera, etc... When it got kinda complicated, the watchdog lost its appetite.
The robot boot fine, but whenever we enable it, the driver station immediately says "Watchdog Not Fed".
I don't think that the robot even initiated the Teleop Init function right... We fed the watchdog function plenty of times, but it still won't feed...
JabbaScript
Unread 02-24-2010, 01:54 PM
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Watchdog Not Fed!
The most typical mistake is if you have a Wait somewhere in your code that is longer than the watchdog expiration. Wait is blocking. So while you are waiting, the watchdog starves. We don't use Wait in our code at all. We wrote our own timer callback using the Notifier class. We also implemented a state machine so that we do non-blocking wait using the timer callback to advance the state machine to the next state.
Unread 02-24-2010, 03:26 PM
masoug's Avatar
Food Consumer
FRC #0114
Exclamation Re: Watchdog Not Fed!
We did not have any
Code:
Wait()
's either, but the thing is that the watchdog IMMEDIATELY does not get fed, so it is some problem with the initialization of our robot...
I think it might be the camera's
Code:
camera = AxisCamera::GetImage()
or something like that, OR it might be PID...
Has anyone ever have this problem before?
JabbaScript
Unread 02-24-2010, 05:03 PM
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Are you disabling the watchdog during autonomous and during the constructor? The watchdog could be expiring before the teleop function sets it up properly
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 02-24-2010, 05:08 PM
mikets's Avatar
Software Engineer
I don't understand your code. Did you mean:
Code:
camera = AxisCamera::GetInstance();
or
HSLImage *image = camera.GetImage();
If it is really the first one, then it means the code failed to communicate with the camera. There are a number of reasons for that.
  • Make sure the ethernet cable is a cross over cable.
  • Make sure the camera is configured correctly with the correct IP address and acct/password
  • Although I haven't verified it myself other threads said the subnet mask of the camera should be 255.0.0.0.
Unread 02-24-2010, 07:59 PM
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
We had a similar problem. Discovered that the accelerometer was plugged into to the duplicate I2C _OUT_ ports. The accelerator initialization in the robot constructor was simply hanging, so our robot class never made it out of its constructor. So, as soon as the robot was enabled, the watchdog went hungry because our code hadn't started feeding it yet.
I guess the lesson from that is: make sure your code is getting to where you think it is, and check everything.
Michael Andrews
Team #281 Programming Mentor
Watchdog not fed brianelite C/C++ 12 03-14-2010 02:43 PM
Enabling yields one "Watchdog not fed" flash Dylan5019 Programming 4 02-12-2010 11:45 PM
Autonomous Independent Code Issue Watchdog not fed pilum40 FRC Control System 0 02-11-2010 12:00 PM
Watchdog Not Fed but, All Systems Are Go. DHSrobotics Java 4 01-24-2010 10:01 PM
Watchdog not fed ahudson Programming 1 01-22-2010 11:26 AM
