Go to Post Good Luck all - this one will hurt your brain, but it's all in a good way. - meaubry [more]
Unread 25-02-2010, 09:37
eccmaster eccmaster is offline
FRC #2344
eccmaster is an unknown quantity at this point
archimedes screw
Hello
I am helping a FTC team with an archimedes screw design to lift a 3 inch diameter ball. Does anybody know how to design the spiral patter to cut it out of sheet metal.
Thanks
Unread 25-02-2010, 09:41
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
Re: archimedes screw
cut multiple doughnut shaped pieces and make a slit along its radius. connect the pieces together with fastener of your choice. Picture a slinky with a slit down one side. The resulting pieces are what you have to make
Unread 25-02-2010, 10:20
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I would highly recommend starting with cardboard to get practice and test it out first - we took a serious look at it last year for Lunacy, before finally giving up on it as being way to intensive to build for the team.
Unread 25-02-2010, 11:30
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
+1
+1
Think about putting the doughnuts around a pipe with some simple angle brackets.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 25-02-2010, 11:45
mvealey's Avatar
mvealey mvealey is offline
FRC #1727 (REX)
mvealey is an unknown quantity at this point
The disk method is the way to do it and prototyping with card stock so you understand the process is a must. Start with a few disks the diameter you need; the diameter of the balls X2 + the diameter of the support pole + 1/2 inch for a fudge factor. Assuming 3 inch balls and a 1/2 inch support pole, a series of 6 1/2 to 7 inch disks will just about do the job.
Make the holes in the centers of the disks the diameter of the support pole. When you cut the holes in the centers you might want to leave a little material to make attachment tabs. I recommend making a series of slits frin the center to the pole diameter size.
Make a cut from the center of the inner hole straight to the outer edge. This is where you'll attach the disks to one another.
Stack the disks with the slots aligned and take the left slot edge of the top one and tape it to the right slot edge of #2. Then the left of #2 to the right of #3 and so on.
Good luck!
Unread 25-02-2010, 15:09
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
One of my favorite methods for making a spiral was to bend two pipes into a spiral, and use them as tracks for the ball to roll on. You'll probably find that it's a bit easier to make than trying to find an approximation of a shape that can't actually be flattened.
Unread 25-02-2010, 16:09
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Heres an example of the "donut" method, used in one of my architecture projects. I really think its the easiest spiral to make/understand.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Mysterious Screw Tanner General Forum 35 27-02-2010 16:08
pic: Screw 1 Robo_Coyote Extra Discussion 3 03-02-2007 02:14
Archimedes Screw Greg Perkins General Forum 10 19-01-2005 11:19
Terminal Screw Strips? Jay05 Electrical 2 09-03-2003 21:48
Screw jack system Gui Cavalcanti Technical Discussion 6 19-01-2003 13:07
