Go to Post My fondest memory was asking questions about Spirit and Opportunity to a NASA scientist while dressed up in a lion suit. - Adam Y. [more]
Unread 25-02-2010, 14:51
Kevka's Avatar
Kevka Kevka is offline
FRC #0975
Rookie Year: 2010
Kevka is an unknown quantity at this point
Customized Control Station
Hi,
is anybody planing on building a customized control station?
What are you going to do?
I was thinking about making a custom program for the PsoC µC, but first I am not completely sure if that's legal and second I would have to have the source code for the default program in order to implement the communication between the µC and the driver station program running on the class mate.
So what are your ideas?
Kevka
Unread 25-02-2010, 14:57
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Customized Control Station
If you are using the PSoC in the competition, you are required to use the firmware provided by FIRST with it. The only software thing you can change with the DS is the Dashboard
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 25-02-2010, 15:13
Kevka's Avatar
FRC #0975
Rookie Year: 2010
OK, so does anybody know if you can have a second µC "talking" to the PsoC3? The manual says that you are allowed to connect portable devices like a Laptop or a PDA via the PsoC/the breadboard. What about custom circuits?
Unread 26-02-2010, 18:11
AKA: Ian Thompson
Rookie Year: 2010
I believe anything goes if it is through the PSoC
Unread 09-03-2010, 15:13
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
I have a question, do you have to use the classmate computer or can you use another laptop instead. If you do have to use it, where can I find the rules that say you have to use it.
Unread 09-03-2010, 15:40
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Please don't post the same question in multiple threads.
Answers always can be found in the FIRST Manual:
Originally Posted by FRC Manual - The Robot
<R80>The DRIVER STATION provided in the KOP is the only system permitted to collate driver/operator inputs and communicate them to the ROBOT. Operator Interfaces and devices from previous FIRST competitions shall not be used.
DRIVER STATION - The collection of the Classmate PC, FirstTouch I/O Module and breadboard provided in the KOP, and a USB hub (either the one provided in the KOP, or a team-supplied USB hub device).
Ricky Quinones
Director of Sales - VEX Robotics
Control Station Mando3168 Technical Discussion 1 09-02-2010 12:01
Control Station in Crate? 1708xMr.Roboto General Forum 2 16-02-2009 19:52
driver station control suitcase lenny8 General Forum 12 06-02-2009 11:43
Height of control station Balanor General Forum 2 31-01-2003 11:20
Control Station Fabrication Question... Jim Meyer OCCRA 1 25-09-2001 05:15
