Go to Post Defense is a good thing! - Kevin Sheridan [more]
Unread 26-02-2010, 11:09
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Check for Enhanced I/O
I want to have the operation of the robot change depending on whether or not the IO board is plugged into the classmate. Normally we have controls through Joystick and PSoC, but there is a special circumstance where the Classmate needs to be portable without anything but the E-Stop button. Is there any way to detect whether the I/O board is connected to the classmate?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 26-02-2010, 11:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Check for Enhanced I/O
You could use one of the input pins as a flag that it is present, as long as you don't set that input in the virtual I/O controls when it isn't connected.
Unread 26-02-2010, 11:39
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
If you are using the "Enhanced I/O" mode (truly the enhanced mode, using the DriverStationEnhancedIO class) you can call DriverStationEnhancedIO::GetDigitalConfig() using any legitimate channel number. If the board is not present, it will return DriverStationEnhancedIO::kUnknown.
We had to do this when using the EnhancedIO, wrapping all our runtime EIO calls inside an "if" checking that the Cypress board was plugged in. Without that, repeatedly setting outputs/reading inputs through the DriverStationEnhancedIO would spam errors through to the Driver Station diagnostic window causing poor connectivity between DS and robot.
Analog Out on the Cypress PSoC (enhanced modeO gokul Programming 5 23-02-2010 14:05
'Enhanced IO Missing' error Ethan E Java 2 19-02-2010 22:51
Power for system check SciDKelly134 General Forum 3 16-02-2009 12:10
Digitally Enhanced Scouting System, DESS falconmaster General Forum 1 16-04-2007 13:05
842's "Digitally Enhanced Scouting System" ChuckDickerson General Forum 6 06-04-2007 11:44
