pic: Team 980 Breakaway robot
Re: pic: Team 980 Breakaway robot
Nice. I like the belt drive. Were you able to take advantage of the Gates offer?
Unfortunately, the Gates offer didn't include belt sprockets quite large enough (D = 5.5"). Our custom sprockets were fabricated by our new team member, Schroeder Torsion Bars in Burbank.
nice looking robot, how do you move the ball and it looks like you have a ball holder... no chain either?
The foam roller provides ball control and is driven via a CIM/AM planetary gear combination using belt drive. The kicker is driven by enclosed compression springs with a pivot point that puts the kicker "over center" in the cocked position. A winch using two window motors reels up the kicker. We use a large cam on another window motor to push the kicker down through center to fire the shot. The kicking mechanism requires just three limit switches for operation: one on the kicker, one on the winch, and one on the cam. |
Why such large sprockes? Are you using your belts to double as a tread drive while you go over the bump?
It appears that you have a suspension on the front wheels, with the pivot 3"-4" ahead of the center wheel axle. If this is the case, it seems as though the center to center distance will change between the front and middle wheels, which would lead to the belt tensioning and loosening based on were the front suspension is in its travel.
If the above is true, how do you handle this? |
Early in the season there was talk on 1714 of using a 6 wheel drive with pulleys between the wheels like this one to double as power transmission and bump climbing aid. Is this why you guys decided to go for timing belt, or did you guys have other reasons? I'm interested in alternatives to roller chain for drivetrains, so any info is appreciated.
http://forums.usfirst.org/showthread...ighlight=chain I know the teams that I mentor saw it as no issue they were designing their robots as well... Looks like we are going to be ordering smaller gears and installing them on thursday! Good luck! |
#11
good to know...
I would think that Belts are going to have more traction than metal, but that's just me. |
#13
They probably do (though less than roughtop). The rule doesn't limit traction, just metal as a traction aid (mainly due to carpet damage, etc).
| pic: Team Paragon 571 2010 Final Breakaway Robot | O'Sancheski | Extra Discussion | 7 | 07-03-2010 21:38 |
| 1986 Team Titanium Breakaway Robot | jspatz1 | Robot Showcase | 12 | 28-02-2010 20:02 |
| pic: Spam's 2010 Breakaway robot | CaptainMcfuddel | Extra Discussion | 8 | 26-02-2010 21:40 |
| Team 39 - 2010 Breakaway Robot! | BornaE | Robot Showcase | 7 | 23-02-2010 23:25 |
| pic: Team 980 Robot 2008 in LA | ThunderChief | Extra Discussion | 3 | 13-04-2008 17:06 |
