Go to Post You win Worlds by innovation. You win Worlds by determination. You win Worlds by engineering a robot so solid, that it successfully completes the game. - Zach O [more]
Unread 28-02-2010, 02:13
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Java Native Interface (For using code made in windriver)
Is there a way to either use Java Native Interface or JNA to combine C++ code compiled in windriver and Java code from netbeans, to run on the cRio?
From poking around the ported Java vision libraries, it seems as though JNA is used, so C++ code is being called.
How would one go about writing C++ code in windriver that could be used in Java?
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Multithreading with Java? Anyone using it? adamdb Java 2 07-02-2010 23:39
connecting to Crio using windriver Tds123 Programming 1 27-01-2010 13:21
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Where can I find camera tracking code for Java? nikRbokRz Java 4 20-01-2010 23:35
Using kevin's code for driving and camera tracking razzoc Programming 3 18-02-2007 08:50
