Go to Post The secret to this whole thing is that it's the robot that builds the team. - JohnBoucher [more]
Unread 01-03-2010, 14:22
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
Wind River Workbench Not Loading
OK here's a new one for you:
I go to open up Wind River Workbench. The splash screen displays, then after a short time, a blank, gray application window pops up and very quickly disappears. No indication that eclipse, javaw, blah blah blah is running in the background - it's like it launches then immediately terminates.
I've reinstalled the application several times - no luck. This install was working perfectly prior to this issue.
I recall seeing a Wind River Registry icon in my system tray - that is no longer there.
No other applications are affected - the laptop is running fine otherwise. Windows XP.
Any suggestions on how to get rid of this garbage? I've got it running on another laptop, but that is not ideal.
Thanks,
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 02-03-2010, 07:06
O-H
Re: Wind River Workbench Not Loading
No takers, eh?
Well then, how about this - how do you completely UNINSTALL Wind River Workbench - clean the registry, start from a clean slate? There is no option under Add/Remove programs, nor any other shortcuts that I can see.
I get the feeling that some file or setting is corrupt and needs banished to PC hell before this thing will be fixed....
Unread 02-03-2010, 07:54
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Originally Posted by Travis Hoffman View Post
No takers, eh?
There should be a directory named 'uninstaller' under c:\WindRiver.
Inside, should be 3 to 5 other directories that contain individual uninstallers (compiler, vxworks, board support, etc.).
You need to run each, in no particular order.
AFAIK, Workbench doesn't infest the registry, so you shouldn't need to worry about that.
Look in c:\Documents and Settings\<your username>.
If there are any files or directories that are obviously Workbench related, delete them.
Look for 'workbench*', 'wr*', etc..
Finally, delete c:\WindRiver.
Note that it is safe to just skip the uninstallers and blow away c:\windriver, but people tend not to believe me when I tell them that.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 02-03-2010, 13:41
O-H
It works now.
I originally tried deleting the entire windriver directory, but it wouldn't let me trash everything. I had read about the uninstaller directory earlier, but I couldn't find it where the resource told me it would be - a Windows search dug deeper to locate it. I ran those, and just for fun, I then renamed my computer before reinstalling, based on a control system forums post detailing a related Wind River problem. "Dell" was a rather lame name, anyway .
Back up and running - why they bury the uninstalls so deeply, I'll never understand. Thanks for setting me down the correct path.
Unread 02-03-2010, 13:58
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
It works now.
Out of curiosity, do you let multiple users (Windows login users) use Workbench on your machine?
As long as there are no Wind River processes running, you should be able to completely delete c:\windriver from the Windows explorer.
If the registry is running, that would probably be a problem.
Obscure Wind River Workbench Problem {td} C/C++ 16 21-01-2010 10:11
WPI update for Wind River Workbench deletes wizards? correnos Technical Discussion 0 16-01-2010 10:08
Wind River Cds Team1710 C/C++ 0 22-09-2009 10:57
Teams happy with Wind River Workbench? gvarndell C/C++ 59 28-07-2009 21:13
SVN wind river Mr.Macdonald C/C++ 3 13-01-2009 12:40
