Go to Post i just want to say how awesome the high volume tank is. The high volume tank is 7/4 as awesome as the previous tanks. - Tytus Gerrish [more]
Unread 01-03-2010, 17:24
Zanfardino2892's Avatar
Zanfardino2892 Zanfardino2892 is offline
AKA: Mark Zanfardino
FRC #2892 (Hottie Botties)
Team Role: Mechanical
Zanfardino2892 is an unknown quantity at this point
Exclamation Help Wiring Pneumatics
We are making some last minute decisions and have decided to work with pneumatics, we have a guy programming and its up to me to wire it. I have not worked with pneumatics before. Problem. I need a diagram showing all standard wiring to the digital sidecar and the wiring to the CRIO for the pressure switch, Festo double solenoids, spike relays and pressure switch, i haven't found a single wiring diagram. Any help would be much appreciated.
"Thats not a good way to store the CRIO"
"Should I move it?"
"No Its fine"
Unread 01-03-2010, 17:47
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Help Wiring Pneumatics
Zan,
Check the First website for pneumatics manual and the Robot wiring diagram Rev B. The wiring diagram has more than one page and the pneumatics manual should fill in the blanks. A solenoid driver module in slot 8 of the Crio will handle 8 valves and can be wired for 24 volt valves. You will have a lot of help at your first event. All you have to do is ask. Check with your Lead Robot Inspector if you are too shy to ask the team on either side of you for help.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-03-2010, 18:01
The teams are very helpful at the events but we want to set up a system for testing right now. i looked in the pneumatics manual on usfirst.org and i'm not seeing a wiring diagram, just the pneumatics circuit, I still don't quite know where to place the PWM,s from the spike relays and pressure switch to the digital side car.
"Should I move it?"
"No Its fine"
Unread 01-03-2010, 20:40
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
LabVIEW's Solenoid with Compressor diagrams the wiring:
http://www.chiefdelphi.com/forums/at...3&d=1265585751
It doesn't cover the solenoids, but this wiring diagram does: http://www.usfirst.org/uploadedFiles...ution_RevA.pdf
I got your email, but I can't use attachments were I am now to send you diagrams.
Plenty of help to be found here though...
Unread 02-03-2010, 17:50
Ok. Thank you very much.
"Should I move it?"
"No Its fine"
Help with pneumatics wiring peter1626 Pneumatics 10 24-01-2010 16:36
Wiring / Pneumatics paigetee Inventor 5 08-03-2009 15:13
Wiring/ Pneumatics paigetee Inventor 0 10-02-2009 16:28
Wiring Pneumatics Switch Simpson Pneumatics 3 11-02-2004 12:32
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
