Go to Post Our robot attacked our programmer autonomously. - sanddrag [more]
Unread 02-03-2010, 19:45
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Team 2470 teaser!
So since we never actually took a picture of our finished robot, I have a picture of our robot for you from week 2 or 3 I don't remember which. You can see kind of what our robot will look like, we did add a bunch more stuff, but you can wait until the competition to see that.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 02-03-2010, 21:08
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: Team 2470 teaser!
Why have 4 toughboxes for a tank steering 4wd? Why not chain up the front and back wheels? Are you changing the wheels to mecannum?(sp?)?
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 02-03-2010, 21:43
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
Well it actually is 8 wheel drive, you just can't see the other 4 wheels because they are not there! We welded 8 more angle iron things on and put 4 smaller wheels in that are powered by the CIM motors so we can make it over bumps without breaking our kickers. We have 2 kickers on our robot one mounted in front and one in back, they each vary in power one for kicking it across a zone to score, and the other to kick a ball all the way across the field/into another quadrant.
This picture shows about where 2 of the smaller wheels were placed, I circled them in red.
Unread 03-03-2010, 01:34
I still don't understand why you don't have both CIMs for each side go through one toughbox and then chain up all 4 wheels together. It would save you the weight of a toughbox at the cost of one more loop of chain (a good tradeoff IMO).
Unread 03-03-2010, 10:14
Chris is me's Avatar
AKA: Pinecone
It's a little late for that... (Though he's right unless you're doing something freaky / interesting we can't see here)
How do you guys deal with turning scrub? How about kicking? Don't get too good, or you guys won't be around for the second round of the draft this year .
Unread 07-03-2010, 23:46
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
Well we have a kicker in the front that uses a pivot point and surgical tubing to fire. We have tested it to go over into at least the quadrant next to us, but we have not tested it on a full sized field yet. We use a pneumatic piston to reload it into a gate latch, then we use a motor to open and close the gate latch. In case our motor breaks down, or the system breaks, we also have a much smaller pneumatics piston to open and close the latch. Our second kicker placed on the opposite side of the first kicker, kicks a ball just far enough to score it into a goal from the far side of a quadrant, it also serves as a pusher. The second kicker is just a Pneumatics Piston with a special attachment on the end. What exactly do you mean by "How do you guys deal with turning scrub?" I am not quite sure I understand what you are saying? And I think we will still be around for the second draft, unless the new rules on the qualification points somehow boost us, to me at least it seems the new rules base the game more on luck.
Unread 08-03-2010, 10:07
AKA: Pinecone
Turning scrub is the friction generated by wheels when you turn in place. When your wheels all have the same traction and you have a longer wheelbase than wide, it becomes very hard to turn in place and it draws a lot of battery current. If it becomes a problem for you at competition, a super quick fix is to use the kit "slippy wheels" on one side of your drive. While you're more easily pushed on that side, you'll have easier turning.
Unread 08-03-2010, 14:50
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
Ah, I see what you mean!! Yeah I was going to run the practice match with 4 sticky wheels, and if that didn't work out for me while driving I was going to have our mechanical team replace 2 of the sticky wheels with slippy wheels. And I don't think I will have much of a problem with being pushed this year, I got a lot of training last year on harassing the other alliance's driver's robots
Unread 08-03-2010, 14:52
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Be very careful carrying assumptions from Regolith to carpet.
Team 2470 Tank Robot ehochstein Robot Showcase 15 27-07-2009 19:01
pic: Team 2470 Tank -- Giving to mentors (who luckily don't use this site :D) ehochstein Extra Discussion 1 01-06-2009 14:05
Thank you Team 3007 and 93! (Congrats to 2826, 1714, 2470) keehun Thanks and/or Congrats 4 09-04-2009 13:55
Team 2470 -- 2009 Robot ehochstein Robot Showcase 7 22-02-2009 23:28
The most revealing teaser of any team yet!!! TEAM 41's UNIQUE BOT DoomdayX Robot Showcase 10 02-02-2005 20:12
