Go to Post Why is it whenever you tell someone there is a million billion stars in the universe they believe you, but if you tell someone that the bench over yonder has wet paint, or if usfirst.org comes up as the 1st result in Google people have to try it for themselves? - artdutra04 [more]
Unread 03-03-2010, 02:28
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Charging pneumatics system before match
After we precharge the pneumatics system at the pit, do we have to wait until the autonomous mode before we can charge the pneumatics system? I searched on CD but most of the posts are about off-board compressor in terms of pre-charging.
The only other way I know how to charge the system is to tether to the cRIO and enable the robot while it is on the robot cart.
Is there an easier way?
Please don't call me Mr. Ed, I am not a talking horse.
Unread 03-03-2010, 08:14
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Charging pneumatics system before match
Ed,
There currently is no ruling on when or if a team can pre-charge their pneumatic system prior to entering the field other than for off board compressors. In my opinion, safety demands that no robot be pre-charged in the pit and left in an energized state while waiting in the queue. Teams that use off board compressors should be given time to charge while on the field during setup but again there is no rule on that. In the past, the event managers decided when, how and if teams could pre-charge their pneumatics.
For all off board compressor users, please be advised that the KOP compressor or equivalent, must be under Crio control when charging the pneumatic system.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 03-03-2010, 11:00
Ed Law's Avatar
I forgot to mention that we have an onboard compressor. I probably should not have used the term pre-charge because it made it sound like we have an off-board compressor. I have to charge it somehow before autonomous period start or the kicker is not going to work. When will they allow teams to run the compressor? In disabled state, the compressor does not run. The only way I know is to enable it through tether to cRIO while in queue. Or will they allow teams to do that on the field before autonomous period?
Unread 03-03-2010, 11:21
Unsung FIRST Hero
Rookie Year: 1996
Ed,
I don't have an answer for you yet. I would think the safest is on the field but that would add to the field turn around time.
Al
WB9UVJ
www.wildstang.org
Unread 03-03-2010, 11:27
Ed Law's Avatar
How do they do it in past years? This is our second year in FRC and first time using pneumatics so we don't know what to expect.
Unread 03-03-2010, 11:28
Unsung FIRST Hero
Rookie Year: 1996
I think the determination was done on an event by event basis.
Al
WB9UVJ
www.wildstang.org
Unread 03-03-2010, 11:32
DonRotolo's Avatar
Back to humble
FRC #0832
At NJ we arrived on the field pre-charged, with a safety lock-out (a metal bar with a long bright pink flag attached to it) that was the last thing pulled off the robot before the team left the robot on the field.
Checklist: Robot on, thinkamajig set, autonomous set, safety bar pulled.
Unread 03-03-2010, 14:39
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
Gotta love the use of universal technical terms, along with whatchamacallit, doodlespiel, whosiwhatsit...
Unread 03-03-2010, 19:10
1t5h1e1o's Avatar
1t5h1e1o 1t5h1e1o is offline
Das boot.
AKA: Theo Matt
FRC #1511 (Rolling Thunder)
Team Role: Leadership
1t5h1e1o is a jewel in the rough1t5h1e1o is a jewel in the rough1t5h1e1o is a jewel in the rough
Send a message via AIM to 1t5h1e1o
Ed,
In 2008 we used pneumatics for our arm and gripper. What we would do is have the controls all set to charge went we got into queue and then with one minute left in the match before ours, charge it up. This way we aren't walking around with a robot that is "locked and loaded", but at the same time we weren't delaying the start of the match by doing it on the field during match setup.
Now, there wasn't as much of a risk with stored energy then like a kicker this year, so I would definitely recommend a safety bar/latch of some sort.
2010 FLR Engineering Inspiration Winner, 2010 Boston Chairman's & Coopertition Winners!
2009 FLR Entrepreneurship Winner; 2009 Chesapeake Website, Imagery, & Chairman's Winners!!!!
2008 FLR Engineering Inspiration Winner; 2008 Philly Safety & Imagery Winners
2007 FLR Chairman's Winner!!! 2007 Boston Spirit & Website Winners
Record on the Field: (2008-2010) 61-45-3
Unread 03-03-2010, 19:37
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Tetra year was the last year we needed to pre-charge, and we did it in the queue also, when the match in front of us was almost over.
This year we can fill the tank(s) in the pit, our system doesn't fill cylinders until autonomous starts.
Unread 04-03-2010, 07:54
Unsung FIRST Hero
Rookie Year: 1996
Originally Posted by 1t5h1e1o View Post
Ed,
I like this approach very much!
Al
WB9UVJ
www.wildstang.org
Unread 04-03-2010, 08:05
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Our team is going to start with pre-charged pneumatics because they keep our kicker locked in a safe position. In fact, all of our pneumatics are designed to store in a safe position with the power off, so our robot is arguably safer with the pneumatics completely pressurized.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 04-03-2010, 09:29
Unsung FIRST Hero
Rookie Year: 1996
James,
You will have to convince your Lead Robot Inspector at each event you attend. I find this hard to believe without seeing it.
Al
WB9UVJ
www.wildstang.org
Unread 04-03-2010, 10:51
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
In the last three years that we've used pneumatics (2006, 2007, and 2008) we would pressurize the system prior to the beginning of the match. We would wait until there was about 1 to 2 minutes left in the match before us and then tether our robot and let the compressor run. This meant that our robot was only charged for a minute or two at most before the match actually started.
Provided this approach is deemed acceptable this year we will probably do the same. Also, our robot will be set so that the kicker is in the fired position as the starting position. This should help to prevent any accidents that could be caused by the kicker firing by mistake.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #15   Spotlight this post!
Unread 04-03-2010, 10:55
Unsung FIRST Hero
Rookie Year: 1996
Dustin,
Just to be sure, your kicker will not be outside of the frame perimeter at the begining of the match?
Al
WB9UVJ
www.wildstang.org
Charging a System Zultraranger Pneumatics 7 05-02-2008 21:08
pic: MARS making repairs before the last match Billfred Extra Discussion 3 10-09-2007 16:52
Spring pulling before match or while in match?? Bomberofdoom Technical Discussion 3 11-01-2007 08:03
pic: 1072 before the match Billfred Extra Discussion 1 06-01-2007 22:30
Pump operation before match Jeff Waegelin Pneumatics 19 29-04-2003 09:42
