Go to Post Some of your terminology is also a little confusing. Nothing that some massaging can't fix. - JVN [more]
Unread 03-03-2010, 12:24
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Wire color...
Hi All,
Once again I find myself apologizing for asking a question whose answer may be easily found... ...by someone but not by me.
Is there any rule that defines the wire color between a motor and its driver device (a Jaguar, in my case, but the question applies equally well to Victors and Spikes)?
I know that 12V and ground going TO the motor driver device has to be certain colors by rule but I could not find anything that defined the color going between motor to driver. I also know that there are rules on minimum gage (based on fuse size, if I understand it correctly).
Finally, I also understand that, generally speaking, in FIRST rules, what is not forbidden is allowed, but I fear that I have missed something.
Thoughts?
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Signal wire gauge and color. sparrowkc Electrical 4 10-03-2010 19:51
Does the Trackball Color Match your team Color??? ZInventor Kit & Additional Hardware 14 07-03-2008 20:09
Color? neilcooper Technical Discussion 2 11-01-2005 16:58
Team Color DrWorm Control System 1 02-02-2004 19:02
Link color Jack Website Design/Showcase 4 19-11-2002 16:31
