Motor gear ratio question
We are using currently for the robot a modified version of the Toughbox (Different housing, same gear ratio) in a 4X4 drive that is than geared by a 15 tooth gear to a 60 tooth one. However we are currently facing a huge weight problem, our robot is about 2 pounds overweight, and we still have parts to add. We thought about lowering the gear ratio of the gears after the Toughbox in order to save weight in both the size of the gear and in chain. We already tried holing the gears but to no avail, it didn't solve the problem and we don't have any metal plates or the likes from which weight can be taken. Our question is whether we would still be competitive after lowering the gear ratio?
BTW, any other weight saving tips will be very much appreciated ![]() ~Kenneth Team #2212 The Spikes |
Re: Motor gear ratio question
Without knowing more it is hard to answer.
When I need to save weight (basically every time I build a robot), I look for big things I can live with out. Toss something overboard so you have the weight to bring something else you like more onboard. By the way, you have to check your ego at the door. The last thing you want is to have a system on board eating up your weight budget just because you were too proud of it to allow a more important system get ahead of it in line. Think about priorities and start cleaning house. Joe J. P.S. Did I use enough mixed metaphors for you? Because I can use more... ...no really, I can... JJ |
You could also think about using the aluminum gears from AndyMark
http://www.andymark.biz/am-0143.html http://www.andymark.biz/am-0521.html And the spacers http://store.andymark.biz/am-0156.html This would save about 0.85 pounds per transmission according to AndyMark. I have never used these products, but I have heard that they are the same great quality as everything else AndyMark. |
Try looking at this presentation for other ways to save weight. http://www.chiefdelphi.com/media/papers/2220
Thank you very much for your input. The presentation had been a very useful one. However we found out that we had miscalculated our weight and so our weight problem is summed up at 70 grams and not 2.07 kg. In the end we decided to keep the gear ratio the way it is at something along the lines of 1:48.
| FisherPrice Gear Ratio | lproxster | Motors | 1 | 03-02-2010 18:33 |
| Best Gear Ratio? | Triforce11 | Motors | 3 | 22-01-2009 17:02 |
| gear ratio | Sam2197 | Technical Discussion | 19 | 21-11-2008 16:39 |
| motor/gear ratio | starsROBOTICS | Motors | 5 | 24-03-2008 10:02 |
| Gear Ratio Math for Cim Motor FP801-005 | KogaVanDragon | Motors | 2 | 14-01-2006 02:38 |
