Go to Post Instead of prototyping with plywood and machining metal for the final version, they make their prototypes out of sheet metal and machine the final robot out of wood. :) - Chris is me [more]
Unread 03-03-2010, 13:23
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Shop safety question
Greetings,
Background:
Over the summer, my team acquired a manual shear press (link to model).
It has sat in the shipping crate due to a lack of an appropriate stand. One of our sponsors heard of this and created a 33" tall cast iron stand for the press. My administration is balking at the idea of bolting it to the floor. They suggested mounting the stand to a plate instead. They have requested that I do some calculations to determine the tipping risk of the press on a plate of undetermined area.
Questions:
1. How do I go about determining the torque required to shear a 1/8" piece of aluminum 4 ft wide? I am a Physics teacher, so i'm familiar with shear stress and the like, but there seems to be so many variables to this (mechanical advantage, area of the cutting surface, ETC.)
2. Is a plate mounting feasible for this application? (I have never heard of this before)
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 03-03-2010, 18:27
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Shop safety question
Wilson,
Are they suggesting a floor plate that the sponsor's stand would then be bolted to? We used some 1/4" steel plate a long time ago to mount some broadcast film cameras on. It is pretty heavy stuff to try and move around. We ended up putting the plate over plywood and then bolted the whole mess to the floor. It is near impossible to find a flat floor unless certain precautions have been take ahead of time.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 03-03-2010, 19:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I've used brakes larger and heavier than that one, with longer legs, and on thicker pieces, I've still had to have a couple buddies pulling on the back to keep from it tipping forward (floor standing unit, not bolted down). It is definitely to your advantage to have the machine as secure as possible. I have seen brakes of the style you linked above bolted to large workbenches, made of 4x4s and a 4x8 sheet of plywood for the top, and that seems to work fine. Since your stand is already made, it looks like you want to proceed down this route. Whatever base you make for it, just make sure it has a really good footprint. If 700+ lbs tipped over onto your leg, you better start looking for a set of wheels.
Unread 03-03-2010, 19:57
CraigHickman
Posts: n/a
My question to the administration would be this: Would they rather put four (or more) bolts into the floor, or have a 700 pound machine crush the legs of a student, who can then sue because the administration didn't let them bolt it to the floor?
Unread 04-03-2010, 00:19
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
They are looking at plate the stand would sit on. I think they have an issue with something being mounted permanently to the floor. I teach in the old "shop" room after they got rid of the shop class. They want an "industrial Expert" to check things out before doing anything. I guess the 3 engineers from Luckstone aren't enough for them...
They just don't realize the scale of what we do. I've brought them into the room, shown them the stand and the shear. I just don't think they get it.
Unread 04-03-2010, 07:50
Unsung FIRST Hero
Rookie Year: 1996
Well certainly you have to satisfy them. But mounting to a plate brings it's own difficulties. How deep do you put the hardware, how do you tap or otherwise make accommodation for mounting, etc. If the person who suggested the plate is not an expert, it might be better to approach them and see what their hesitation might be. A field trip to an actual shop might even help.
Al
WB9UVJ
www.wildstang.org
Unread 04-03-2010, 14:58
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
I think you are going to break that shear if you try to cut aluminum that thick. Baileigh makes a unit just like that that is rated for 20 gauge mild steel and 16 gauge aluminum. 1/16" aluminum is pushing it.
http://www.bii1.com/benders/sbr-5220.php
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Safety Reminder: This is why we should all wear safety glasses! The Megan 2207 General Forum 3 05-02-2010 10:06
**FIRST EMAIL**/Safety Animation Award Update & Safety Quiz Mark McLeod FIRST E-Mail Blast Archive 6 10-10-2008 14:58
Dirty Shop Betty_Krocker General Forum 14 20-02-2008 13:18
Shop Safety Training Resources Andrew Schuetze General Forum 4 14-12-2004 13:28
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
