Go to Post Putting 2 and 2 together, and then mixing them back up for someone else to try and get 4 in a different way is just plain fun. - Elgin Clock [more]
Unread 03-03-2010, 14:49
cardozo cardozo is offline
FRC #2121
cardozo is an unknown quantity at this point
Need Help - Pneumatic Kicker
So, this is how it is: Our kicker is operated by using two solenoid switches. The first solenoid operates a pneumatic arm which pulls the kick into position. The kicker is then held into position with a latch system. The first pneumatic arm has no pressure on it after it is armed into the latch. Pressure from a series of rubber bands tries to pull the kicker in a downward position. The second solenoid switch is used to operate the second pneumatic arm. This second arm unloads the latch, allowing the kicker to move forward.
I am viewing this as two separate systems. One system is programmed to pull the kicker into position. The second system is used to release the latch.
We have already written the program for the kicker, but it doesn’t seem to be working. We are trying to wire it using two spike relays, but this doesn’t seem to be working. We are thinking about rewiring this to the newer bumper system.
Any help would be much appreciated.
Unread 03-03-2010, 15:58
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Need Help - Pneumatic Kicker
First off, there are many threads on this already. Searching them should reveal almost everything you need.
That said, here is an example.
This post even provides an example vi already built that may meet your needs.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 03-03-2010, 16:05
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Correct me if I'm wrong, but don't you wire solenoids directly into the solenoid breakout? In the past I know we used spikes, but I don't think that is necessary anymore (we're not using pneumatics this year, so I'm not sure off the top of my head).
Twitter Profile
Unread 03-03-2010, 16:40
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Both the Solenoid breakout and Spike relays are legal options to power solenoids this year.
Programming Autonomous pneumatic kicker tanguma26 NI LabVIEW 14 07-03-2010 21:40
Team 1522's pneumatic kicker kornjones Robot Showcase 0 15-02-2010 20:59
pic: Pneumatic Kicker Rev_1 professor1212 Extra Discussion 6 17-01-2010 23:07
pic: Pneumatic Kicker Rev_0 professor1212 Extra Discussion 0 17-01-2010 01:15
HELP! We need pneumatic wiring help! BrittanyV Pneumatics 13 10-03-2006 09:26
