Go to Post (This is why Non-Engineering Mentors make the dinner plans for the team...) - KathieK [more]
Unread 04-03-2010, 18:50
meakerb's Avatar
meakerb meakerb is offline
Mentor
FRC #3786
meakerb is an unknown quantity at this point
Digital I/O from driver station vs FirstTouch I/O Module
The programmer for our team has utilized some of the digital I/O on the IO Tab of the Driver Station to send some configuration settings to the robot (unique for each driver). The question is: is there any reason this functionality will not work at competition?
The reason we ask is we don't understand the reason for the FirstTouch I/O Module. The Control System Manual Introduction (chaper 1) calls these the "virtual digital I/O". The system as is works for us, but we don't want to get to the competition and find out we need the FirstTouch I/O Module.
Thanks,
Team 3221
Unread 04-03-2010, 19:14
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Digital I/O from driver station vs FirstTouch I/O Module
If you are comfortable with your set-up, it is fine.
The virtual I/O are great in that they are easy to use and virtual. However, they might not be great for use during competition: Can you imagine hunting with a mouse during a match?
The FirstTOUCH I/O are great in that they can be connected to actual buttons and knobs, which are much easier to use in situ.
If they don't change during a match, I'd go with virtual.
Unread 04-03-2010, 21:40
meakerb's Avatar
Mentor
FRC #3786
Thanks, thats exactly what I had hoped would be the case. And yes, these are set for the driver's preference so won't change during the match.
Unread 05-03-2010, 09:47
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Is this information available during autonomous period? Obviously they can't be changed in that time, but can they be set before the match and read?
Unread 05-03-2010, 23:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Yes, and yes. This is a new feature of the control system this year -- instead of all joysticks reading neutral and all buttons reading off during Autonomous, their actual state just before Autonomous Enabled is what gets read.
Driver station can't find io module remulasce FRC Control System 2 25-01-2010 01:24
Driver Station Digital Outputs Lafleur Programming 2 10-02-2009 10:50
Driver Station Digital Input Lord_Jeremy FRC Control System 2 09-02-2009 23:06
using digital inputs from the driver station SL8 NI LabVIEW 2 04-02-2009 15:53
Programming Digital Inputs from Driver Station spooncwru Programming 8 01-02-2009 13:14
