Go to Post It is better to err on the side of caution than to put yourself in a position to have a referee or judge make a call against you. Build smart! - Sean Schuff [more]
Unread 05-03-2010, 13:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Inconsistency in Scoring Robot Hanging
At San Diego the head referee is giving two points to any robot that ends the match above the platform at the time the buzzer goes off-regardless of where it ends up when it comes to rest. This was apparently announced at the driver's meeting yesterday and confirmed by her with the head referee at FIRST. This occurred during the very first qualification match of the day when a team hung, but slid to the floor immediately after the match ended.
See G05 as follows:
<G05> Scoring Determination - Scores will be assessed after all objects in motion, when the ARENA timer displays zero seconds, come to rest, or 10 seconds after the timer displays zero seconds, whichever comes first. The final score of a MATCH is the total of points assigned under Rule <G04> less any assigned PENALTIES.
Clearly this is not consistent with the rules. Has anyone at other week 1 events seen a misapplication of G05?
2001-2004: Team 100
2006-Present: Team 254
Unread 05-03-2010, 13:15
Tom Bottiglieri Tom Bottiglieri is offline
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Inconsistency in Scoring Robot Hanging
This one seems pretty black and white... not sure how that rule could be misinterpreted/mis-written.
Unread 05-03-2010, 13:38
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Team Role: Leadership
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
The Head Ref in KC was very clear at yesterday's driver's meeting that all that mattered was where things came to rest, including balls. He said any ball that scores after the buzzer (assuming it was moving before the buzzer), would count. It came into play on a match early this morning where a team got a ball rolling right before the match ended and it ended up scoring after time had expired.
Collin Fultz
Unread 05-03-2010, 14:03
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Applying the rule prior to the robots being powered down would be fairly irritating. Not only is it a judgement call (did they actually get above the platform or not....), a fair bit of work went into many people's hanging system under the understanding that it HAS to lock in place. Indeed, design compromises were made for exactly that reason.......
Unread 05-03-2010, 15:08
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
See G05 as follows:
Is the referee contending that at the moment that the timer displays zero, the robot is at rest, even if for just a millisecond?
If Aidan Browne concurs with this interpretation, life just got much easier for hanging robots!
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 05-03-2010, 15:10
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I just don't believe he did.
Unread 05-03-2010, 15:18
kmitchell kmitchell is offline
kmitchell is an unknown quantity at this point
This could get messy if a robot is swinging when time runs out and then drops below the platform. In this case the robot wasn't "at rest" but was above the platform.
"This was apparently announced at the driver's meeting yesterday and confirmed by her with the head referee at FIRST. "
Sounds like Aidan has already been consulted.
Unread 05-03-2010, 16:09
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
It doesn't sound like what you're being told by your refs is what we were told by the GDC.... perhaps there has been a misunderstanding.... but I can't see how. This rule is pretty clear, and it sounds like what they are doing at your regional isn't this.
Jason
Unread 05-03-2010, 16:12
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Has this issue been submitted to the Q&A? Not that there's ambiguity, but that's probably the best way to get the GDC's attention, I think.
Unread 05-03-2010, 16:25
Cory's Avatar
AKA: Cory McBride
It is quite clear this was not the intent of the GDC. It also seems clear this is an isolated incident. Seems like somehow, someone got confused and now everyone at SD is playing with a different set of rules.
2001-2004: Team 100
Unread 05-03-2010, 19:24
pitzoid's Avatar
pitzoid pitzoid is offline
AKA: BOB
no team (4FX Design)
Rookie Year: 1998
pitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of light
The Amber lights under the ball return chutes will light for 10 seconds after the field timer goes to zero... hint ..... hint....
BotBash BOB Pitzer
Harvest CROO Robotics and 4FX Design
pic: 1751's 2010 robot hanging dmlawrence Extra Discussion 14 20-03-2010 01:53
pic: Our robot hanging. CD47-Bot Extra Discussion 5 07-04-2004 07:59
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
pic: Team 48 Robot Hanging CD47-Bot Robot Showcase 1 01-03-2004 20:22
Drill Motor Inconsistency archiver 1999 10 23-06-2002 22:34
