Go to Post We call ourselves community/family. We are. Our kitchen table where we gather is the size of Chief Delphi. - JaneYoung [more]
Unread 05-03-2010, 21:06
specs101kid specs101kid is offline
FRC #1529 (Cybercards)
specs101kid is on a distinguished road
simple autonomous
Hello,
we would like to have a simple autonomous that drives forward and kicks a ball.
Does anyone know how to do that?
and if so can you help us please?
Thanks
Unread 06-03-2010, 00:44
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: simple autonomous
Sure, no problem.
Seriously, you'll need to make the robot pretend someone is at the controls doing things at exactly the right time to make it do what you want. If you can detail the sequence of events necessary for driving forward and kicking, at the level of "run this motor at 70% power" or "delay 320 milliseconds" or "turn on this pneumatic solenoid valve", you can easily translate that into something that will fit in Autonomous Independent.
If you want to do things based on robot sensor feedback instead of time, you can do that too. You'll just have to have good detail on exactly what the sensors need to read before you move on to the next step in the sequence.
Simple dead-reckoning autonomous JimGRobot Programming 16 16-05-2007 23:59
even simple autonomous code doesn't work?? colman77 Programming 4 17-02-2006 23:58
Simple Autonomous Code Team620 Programming 4 21-02-2005 23:14
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
Simple Autonomous Mode Example deltacoder1020 Programming 5 08-03-2004 20:22
