Go to Post You will find friends among all FIRST students who will become very good friends of yours, will care and help you with anything that you need help with. This is my personal opinion, If you are hooked, dont ever let it go. - Arefin Bari [more]
Unread 06-03-2010, 01:44
CrashTestPilot's Avatar
CrashTestPilot CrashTestPilot is offline
AKA: Rafal Myslak
FRC #2338 (Gear It Forward)
CrashTestPilot is an unknown quantity at this point
Penalties - which ones are most common?
So to those who participated or watched first week matches, what penalties are most commonly issued? Are they mostly due to human error, inferior robot design or rather bad luck?
What I gathered so far from reading week 1 notes, ball protruding more than 3" into frame perimeter is most common. Is this mainly because of fault with basic robot design (frame not built with provisions to stop the ball from getting under the chassis) or is it rather an effect of game play (less obvious design flaws that may not have been discovered during testing? For example, should a driver of a robot with roller type ball magnet be concerned about approaching a ball pinned against wall or another robot? Will robot momentum and ball magnet roller have the unexpected effect of robot driving on top of the ball? How many balls are getting dropped and stuck above the bumper perimeter?
Next frequently quoted penalty is for robot violating size restrictions if they start elevating before the finale period starts and have an unsuccessful attempt, try to reposition and loose contact with the tower.
Also, kicking out of bounds and tipping other robots. What else?
TBA and official FIRST site shows final match results and overall team ranking, but I can't find info on penalties assigned per match. Is that tracked anywhere?
What are the Penalties??? Wayne Doenges General Forum 1 21-02-2010 08:02
please post hints in how to help improve first bot chassis and which ones they r ^^ robotchibi General Forum 8 01-11-2007 16:06
what type of shooter will be most common this year? gondorf Technical Discussion 16 16-01-2006 17:05
Most common.... Brian Savitt General Forum 1 05-01-2002 18:34
