Not Showing Up To A Match - Seeding Points?
I was perusing the FLR standings, and noticed several teams did not play 10 matches as scheduled:
http://www2.usfirst.org/2010comp/eve.../rankings.html 639 played only 8? Was this a result of not showing up to a match? I'm assuming this was the case, which means they received no seeding points for the match? If so, I read a thread about a regional where a team that rarely showed up to matches was ranked 2nd at some point. How could this be the case? Are no-shows being handled differently at different regionals? Could someone confirm what exactly is supposed to happen to no-shows in terms of seeding points? |
Re: Not Showing Up To A Match - Seeding Points?
A no-show receives no seeding points. As in past years all you have to do is send a human player to not be considered a no-show, no robot required.
So if a Human Player is provided, then they still get their seeding points, correct?
Yep, as long as some member of your team is in the alliance box at the start of the match you will get your Seeding Points. The Human Player is usually the one that gets sent, but they don't have to be.
I wonder how strategic it would be to miss a match against an alliance that's doomed to beat you if you're partially functioning.
Isn't it sad that the thought even crossed my mind? ![]() |
Hmm... this year keeps getting more and more interesting.
Things I learned in this thread: 1) NEVER no-show... send someone/ANYONE. The seeding point penalty for no-showing REALLY hurts this year. 2) Have a no-show on your alliance? Probably going to lose the match as a result? No problem... this is the perfect opportunity to "coopertate." |
Though to be completely fair, this has mattered every year. You wouldn't get a win if your alliance did pull off a 2v3 victory if you were a no show.
In past years there was less incentive to play a 2vs3 because it typically meant a loss. This year, although 2vs3 still aren't great, if played right, you will still earn very significant seeding points even if you lose - so long as you play it right. To no-show isn't just walking away from a probable loss, but you're now walking away from very significant seeding points - possibly the same had you won. To me, that makes the penalty for no-showing much higher this year. |
Another reason for less matches is DQ's / red cards. They're relatively easy to get this year. 14 of them in 74 matches at Kettering, none were because of no-shows.
#10
Hey, I am here from 639, and the reason we only "played" 8 was because of 2 DQ's (ikr?). The first red card was due to while we were hanging, and touching the tower, another robot bumped us right while our arm was going down, and we hit the two bars under the ball return. Our drive team decided to go for it anyways, and pulled up. Due to this, the ref thought it was intentional, and gave us a red card. The second one was due to our driver raising our arm before finale. He saw another robot doing it (he was touching the tower) and assumed that we were in finale. Sadly, it cost us a yellow, and then a red card due to the first one. Anyways, we were seeded at 27 due to no few losses after the DQs. They also give you NO seeding score, so it killed our qual rank.
Anyways, we were very successful in elimination, scoring five points while the rest of our team lost connection to the field. |
#11
Looks like your right; I am not the team expert on rules, but neither was our former driver. I wish that our driver hadn't started our winch
![]() In fact, I dont think that we even knew that that was illegal, lol, although we are usually pretty good with rules (no G46 violations!) |
#13
I disagree somewhat. In previous years missing a match didn't mean too much for ranks. I remember a match 1766 couldn't make due to robot fixes. After that round of matches, we went up in ranks. I studied the ranks and noticed something. A team that wins 2 and loses 3 is ranked lower then a team that wins 2 loses 2. This means that missing a match you lose would raise your rank even though you'd lose rank points. I realize this doesn't work for this years game...and am disappointed that it was true for previous years. However, it is true. I've yet to hear of a team that has actually used such a strategy due to the ethics of doing it on purpose.
#14
EDIT: Just for clarification, this is about last year, not this year. Last edited by Eugene Fang : 07-03-2010 at 02:09. |
#15
This wasn't true. You got 2 points for a win and 0 for a loss. Additional losses took nothing from you.
| Manipulator not showing | rastermon | 3D Animation and Competition | 3 | 24-02-2010 11:23 |
| 9.3.4 Match Seeding Points | theycallhimtom | Rules/Strategy | 92 | 25-01-2010 16:18 |
| Changing Rule 9.3.4 Match Seeding Points | Valley Raider | General Forum | 1 | 16-01-2010 15:49 |
| Match Seeding Points | Valley Raider | General Forum | 2 | 16-01-2010 14:22 |
| Match Seeding Points | Katie_UPS | Rules/Strategy | 1 | 09-01-2010 15:59 |
