Autonomous Help?
With New York Regionals Next Friday, im trying to cram a load of work before saturday
we got our teleop all setup but we gotta program encoders for autonomous. any body willing to help us on a more detailed and able to describe or "dumb down" certain things? I understand we have to use state machines. Thanks in Advance |
Re: Autonomous Help?
Not necessarily. It depends on what you want the robot to do.
Our autonomous mode drives forward, turning on and off the ball magnet roller, arming the kicker, and kicking, multiple times, in a specific sequence at specific locations on the field. It uses only the wheel encoder values to control what it does, by turning the encoder counts into a number of inches and feeding the inch value into a case structure. What sequence of events do you want your robot to follow, and how do you want to meter that sequence? |
A simple flat sequence in Autonomous Independent might be the easiest solution, with each frame doing one step of your autonomous process and waiting for the right condition before letting it move to the next frame. |
| HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW | rokenboker | NI LabVIEW | 9 | 05-02-2010 17:10 |
| Autonomous help | rsegrest | Programming | 9 | 13-03-2009 00:10 |
| Autonomous help | csshakka | NI LabVIEW | 3 | 15-02-2009 13:21 |
| Autonomous Help | sudeepr71 | Programming | 14 | 10-03-2004 22:14 |
| Autonomous Help | mightywombat | Programming | 11 | 07-01-2004 10:45 |
