Go to Post I think one of they beauties of the program is how it can include so many different interests our students have. - Doc Wu [more]
  #16   Spotlight this post!
Unread 09-03-2010, 00:39
Chris is me's Avatar
AKA: Pinecone
Re: FP ok to stall?
I can attest to friction driving FPs to prevent stalls. While not yet used in this configuration, I would give it a try if you could.
  #17   Spotlight this post!
Unread 09-03-2010, 01:20
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: FP ok to stall?
Originally Posted by Joe Johnson View Post
I love the FP motors. At least I did before the Thermal protection was added. I think I will end up liking it just as much with the breaker, if not more. They are easily the most power dense motors in the kit. Used with a Dewalt transmission or a Banebot transmission designed to be loaded properly (<1/3 stall torque if planned to be stalled for any duration of time) the motor is a real work horse.
Just one man's opinion.
Joe J.
Seconded! You can't beat them for sheer power. Especially because you actually have the option of running them at 1/2 stall, even if it's not the best idea. You won't run a CIM at 1/2 stall for more than a few seconds before you trip a breaker.
That said, we're using an FP to hold up a ramp this year. We've currently settled on 25% speed as a semi-safe value. We tried 30%, but after a long session of unintentional idling in the pits, the motor was producing some distressing odors. In the interests of my sanity, the students backed it down to 25% and promised to not leave it idling in the pits.
  #18   Spotlight this post!
Unread 09-03-2010, 03:16
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: FP ok to stall?
We learned this the hard way this year.
We tried to use a FP to run a centrifigal fan out of a dewalt vaccuum. It functioned o.k. 1:1 but didn't give us the speed we needed. We geared it up 1:2 and after running 30 seconds wide opened the Fish smoked a bit and thermal-tripped. We thought we had a bad motor since there wasn't that much load on it (it was spinning at a REALLY good clip) so we wired up another and prompty toasted that.
That's how we learned that you don't run an FP at 100% of rated power if you can help it - even if it is not stalled and is still turning pretty darn fast.
  #19   Spotlight this post!
Unread 09-03-2010, 09:30
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: FP ok to stall?
I love data. Nice.
From the above two posts we learn:
  1. The breaker is good, but when you have good airflow (due to high RPM of the motor) it is sort of a marginal protection device.
  2. 1/3 to 1/4 full stall torque looks to be about the upper limit of high duty cycle applications.
One final clarification. From Kevin: "You can't beat them for sheer power." This is not exactly correct. The CIMs do actually beat them for sheer power (300+ W peak power vs. 200- peak power), but the CIMs are much heavier and much larger (even after you include an extra gear stage to slow down the speedy FPs).
What I intended say is that the FP motors are easily the top motor in the KOPs based on both power per unit volume and power per unit weight measurements.
Regards,
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
  #20   Spotlight this post!
Unread 09-03-2010, 10:02
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
Rookie Year: 2007
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Re: FP ok to stall?
Getting back to the original design point, of using a motor to spin roller fast, but possibly allowing it to stall.
In one iteration of 'ball magnet" roller development, we used a polycord loop around a grooved hub on the roller running under light/no tension. We provided a tensioner, but also lubricated the polycord with lithium grease. This allowed us to "tune" the slipping of the polycord on the hub, and allowed stalling the roller without stalling the motor, although the motor would still be "loaded". That part worked great, but we found other ball control approaches that worked better than stalling the roller on the ball. It does allow you to spin the roller fast, but allow it to stall and then recover roller speed quickly.
I think some teams also use pool noodle on PVC tube, taking advantage of the slipping of the noodle on the PVC to keep from stalling the motor, while stalling the roller.
  #21   Spotlight this post!
Unread 09-03-2010, 10:37
Rookie Year: 1998
Re: FP ok to stall?
I love data. Nice.
Regards,
Joe J.
Actually, if you start looking at attainable power, thing get slightly more competitive. The CIM hits max power at 67 amps, which is going to trip a breaker or fault a jag eventually. Granted that's something like 10 seconds for the breaker, but still. If you look at the power at 40 amps, you're down to 280 W. Meanwhile, the FP can pull full power at about 35 amps. The CIM still wins, but it's a bit more competitive of a race.
But yes, even factoring in a 4:1 gearbox to get down to similar speeds, the FP blows the CIM out of the water in power density.
Important discovery pertinent to this discussion:
Our Snap Action breakers are only guaranteed to trip at 135% of rated current. This means if you're protecting a FP with a 40 amp breaker, it may be happily pulling 54 amps indefinitely. Even at 200% overload, the trip time is between 1.5 and 3.9 seconds. And I have a feeling our nice air conditioned environments will trend us toward longer trip times. As such, it's likely much much wiser to use a 30 amp breaker on FPs instead of the usual 40 amp. With a 30 amp, your FP can only pull 45 amps for up to 3.9 seconds, which should do a much better job of keeping it safe.
  #22   Spotlight this post!
Unread 09-03-2010, 12:46
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
Re: FP ok to stall?
We ran the roller last night at 30% and it performed beautifully. As soon as the ball touched the roller, it got pulled in and the motor stalled. We were able to drive forward and reverse at 20% speed keeping the ball with us. The FP thermal never tripped.
This isn't ideal but it'll work for this weekend. Later, we will be building a new gear box for it that will have "too much" torque
"too much" being a theoretical threshold that is never truly reached
  #23   Spotlight this post!
Unread 09-03-2010, 14:09
Rookie Year: 1998
Re: FP ok to stall?
You may change your mind after this weekend. It seemed entirely too easy last weekend to accidentally eat balls, especially when maneuvering near the bumps. If you go with a theoretically unstallable gearbox, it might increase your tendency to eat balls. I think it's something to test before you permanently install it on your bot.
  #24   Spotlight this post!
Unread 09-03-2010, 14:20
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Re: FP ok to stall?
We went with a dual roller that grabbed the ball below the CG and gave it backspin. While it wasn't perfect, it worked very well, and we are very happy with our decision.
It is driven by a FP motor -- that never stalls, because nothing ever gets stuck!
Name:	ball controller.JPG
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
  #25   Spotlight this post!
Unread 09-03-2010, 21:33
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
Re: FP ok to stall?
On a sidenote:
Our team scrapped our roller, but before doing so, found some amazing stuff to create traction on the ball.
http://www.mcmaster.com/#high-performance-tape/=65eqsn
Go to non-stick surface-gripping tape. Buy some of the rayon cloth stuff. It isn't cheap, but it provided so much friction that our fp would suck the ball under our test chassis with two people sitting on it.
  #26   Spotlight this post!
Unread 11-03-2010, 00:36
FoleyEngineer's Avatar
FoleyEngineer FoleyEngineer is offline
AKA: John Crombe
FRC #0910 (Foley Freeze)
Team Role: Coach
FoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond repute
Re: FP ok to stall?
In '08 we winched our catapult down with two FPs. Of course it would stall when we were winched until we hit the fire button. In initial testing, the kids would often keep it tensioned for long periods of time (10 seconds I would guess). Eventually, they smoked a FP and upon looking at it we saw that the plastic fan blades inside the motor housing were actually melted from the heat!
Our solution was to put heat sinks on them from an RC hobby shop (designed to fit around motors that size), and also to mount fans (like the ones on the Victors) that blew continuously over those heatsinks. That kept our FP motors cool even with long stalls and we never blew one the rest of the year through probably 100 matches. Limiting the current helps a ton too. The combination should do the trick. Pick up a non-contact temp probe from Harbor Freight and check your motor temps with various cooling and current systems and you won't have to guess if you're okay or not.
2014 Buckeye Champions - thanks 846 & 639, Troy Champions - thanks 33 & 5193, Imagery, Entrepreneurship & Industrial Design Awards
2013 Kettering Champions - thanks 70 & 862, Three Imagery Awards
2012 Western Mich Finalist - thanks 1918 & 85
2011 Trav. City Web Site, Troy Xerox, Mich State Semi Finalist & Judges Awards
2010 Kettering Champion - thanks 67 & 70, Kettering Rockwell Innovation 2010 Troy Finalists - thanks 33 & 288, and Rockwell Innovation
2009 Kettering QF, Detroit Finalists Detroit Creativity Award, Troy Semi-Finalists Troy Creativity Award
2008 WMRI Finalists - thanks 1243 and 904, 2008 Kettering Champion - thanks 67, 1075 and 2619
2008 IRI Judges Award Winner, Great Lakes Finalists - thanks 66 & 217, Western Mich
2007 Curie Division Champions - thanks 330 & 1270
  #27   Spotlight this post!
Unread 11-03-2010, 01:03
Happy Birthday! Akash Rastogi Akash Rastogi is offline
Re: FP ok to stall?
Heatsinks like Mr. Crombe was saying work really well with FP motors. This year we're using them in our applications and 1323 even used them in their drivetrain. They're the blue heatsinks in this pic. I'll try to get a link to them, they're about 14 bucks IIRC. Edit: http://www3.towerhobbies.com/cgi-bin...&I=LXJHA7&P=FR
  #28   Spotlight this post!
Unread 11-03-2010, 01:34
Vikesrock's Avatar
Happy Birthday! Vikesrock Vikesrock is offline
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: FP ok to stall?
Not sure how different these are but here's what I found while I was waiting for you to post the link:
http://www.rcplanet.com/Motor_Heatsink_s/1247.htm
Unfortunately all the fan designed ones appear to use a fan a little smaller than the one in the kit so they probably can't be easily replaced, but the non-fan ones at the bottom of the page are almost half the price of the ones from Tower Hobbies
  #29   Spotlight this post!
Unread 11-03-2010, 14:03
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: FP ok to stall?
Kevin, could you clarify what you meant here please? When you say "25% speed", did you mean "the voltage that produces 25% of the rated 12 volt no load speed" ?
In other words, adjust the PWM to the unloaded FP to produce a speed of 25% of the rated 12V no-load speed, then - while keeping the same PWM - add load to stall the motor; and it is OK ?
  #30   Spotlight this post!
Unread 11-03-2010, 14:11
Ether's Avatar
Rookie Year: 1969
Re: FP ok to stall?
As a general rule of thumb, unless the datasheet or other documentation says otherwise, most DC motors are designed for continuous operation at about 20% of rated stall torque (aka 20% rated stall current). Operation at higher torques (currents) is allowed, but only intermittently. Ambient temperature, heat sinking, and forced airflow affects the allowable length of the intermittent period.
Toughbox stall torque Galum Motors 4 04-02-2010 15:47
motor stall current vs Victor ratings dawilliams Electrical 30 03-01-2007 08:29
Made to stall srjjs Motors 5 17-01-2003 19:00
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
