Relay Code
Hi everyone,
I have a quick question about the C++ code for spike relays. What are the two arguments in the phrase "relay(x, y)" when I am initializing the relay in the code? One of them is clearly the relay port but what is the other and what is the order of them? Thanks a lot. |
Re: Relay Code
you only need one if you are using slot 4 (default)
if you are not in slot 4, the first is the slot (if it is not 4, it's probably 6), the second is the relay port (on the DSC) if you have it in 4, use relay(relayPort) |
Re: Relay Code
There are two possible constructors for the Relay class (from relay.h). Here are their definitions:
Code:
Relay(UINT32 channel, Direction direction = kBothDirections); Relay(UINT32 slot, UINT32 channel, Direction direction = kBothDirections); Last edited by mikets : 08-03-2010 at 22:39. |
Re: Relay Code
thanks so much guys
| spike relay code urgent | chris janney | Java | 1 | 21-02-2010 17:55 |
| Relay | Robopanda6 | Java | 5 | 07-02-2010 01:08 |
| Spike relay code not working | wywern209 | Programming | 9 | 05-02-2010 22:04 |
| C++ Relay Code? | Happyisgood | C/C++ | 10 | 16-07-2009 14:54 |
| Intermittent CODE ERROR, followed by uncommanded relay switching | tcj103 | Programming | 4 | 22-01-2007 02:59 |
