Re: CAN Cables
CAN does measure the voltage difference between CAN high and CAN low, this is why it is used in HIGH noise environments such as automobiles.
Re: CAN Cables
The decision is often...buy it or build it?
Given the limited amount of programming and development time during the robot build portion of the FRC season, it makes sense to focus on the implementation of CAN in a robot design rather than spending time fabricating cables. Building CAN cables is not rocket science but it is one more thing to do on a long list of tasks in a typical robot build. If you decide to build it...see the Texas Instruments website for Stellaris Jaguar CAN information. If you decide to buy it...see the eStop Robotics website for CAN cables inclduing a CAN Starter Pack. Either approach will give you access to the advantages and features of a CAN enabled FRC robot. Last edited by eStop Robotics : 23-01-2012 at 07:07. Reason: Link correction |
Re: CAN Cables
Good advice you may also visit:
http://www.andymark.com/product-p/am-0967.htm http://www.crosstheroadelectronics.com/Cable.html Andymark has a do it yourself kit, CTRE has both premade and do it yourself along with a video on how to assemble your own cables. |
Re: CAN Cables
I misread the pinouts and ended up connecting all 6 pins. I have the pairs connected from the outside in, which is to say that one pair is on pins 1 and 6, reversed so that the wire on pin 1 on one end is connected to pin 6 on the other and vice versa. Likewise there is a pair on pins 2 and 5 and also one pair on 3 and 4. Does it hurt to have the extra pair on the outside? What about wiring the one marked at no connector that corresponds to the ground?
Re: CAN Cables
I hope this helps. http://www.chiefdelphi.com/forums/sh...an+cable+video |
| Cables | MHSrobotics2853 | Technical Discussion | 4 | 19-01-2010 12:14 |
| PWM cables... Where can i buy them??? | M. Gildner | Electrical | 10 | 11-02-2009 12:31 |
| Y-cables | fishgurl | Electrical | 4 | 01-02-2008 23:48 |
| Can we shorten the PWM cables? | RAWdealer59 | Electrical | 3 | 18-02-2003 15:49 |
| No cables? | archiver | 2000 | 5 | 23-06-2002 22:43 |
