Go to Post A Strong FRC Team Should... have a clear vision and an understanding of how to achieve it within their means. - jwfoss [more]
Unread 09-03-2010, 21:28
archwaykitten archwaykitten is offline
AKA: John McBryan
FRC #1212 (Sentinels)
archwaykitten is an unknown quantity at this point
watchdog not fed when "enable" is first pressed
In labview, whenever we first hit "enable", a message briefly flashes saying the watchdog is not fed, and then after a fraction of a second it will go away and we'll be able to control the robot just fine (and won't get any more watchdog not fed messages for the duration of a match). If we click disable and then enable again, we'll get the same "watchdog not fed" message.
Is this okay, or will this cause our robot to shut down in competition at the very start? I'm hoping a brief watchdog failure upon startup is actually expected and okay.
And is there a practice mode we can use that will mimic the competition mode? If our robot is going to shut down in competition, I'd like it to shut down for our practices too, so we know.
Unread 09-03-2010, 22:03
garrettg garrettg is offline
FRC #1528 (Monroe Trojan Robotics (formerly iPirates))
garrettg is an unknown quantity at this point
Re: watchdog not fed when "enable" is first pressed
Well, I have good news and bad news.
Good news is that our team has the same problem, and I don't think you have anything to worry about.
Bad news is that we have not been to competition yet, so I can't say for sure.
Good news is that in the driver station, there is a button below autonomous and teleop that says practice, and that gives you the 15 second autonomous and a limited teleop.
Unread 09-03-2010, 22:10
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Rookie Year: 1999
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
That is normal, and documented behavior when switching from disabled to enabled.
We've been to a competition already with it. It doesn't matter.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 09-03-2010, 22:50
AKA: John McBryan
Excellent. Thank you.
Watchdog not fed brianelite C/C++ 12 14-03-2010 14:43
Enabling yields one "Watchdog not fed" flash Dylan5019 Programming 4 12-02-2010 23:45
"watchdog not fed" error Lumit NI LabVIEW 8 04-02-2010 18:45
Watchdog not fed ahudson Programming 1 22-01-2010 11:26
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
