Go to Post Can't we also care about and celebrate the processes, the professionalism, the experience of healing? - Taylor [more]
Unread 09-03-2010, 21:40
Billyfred's Avatar
Billyfred Billyfred is offline
AKA: Connor Hall
FRC #1566 (Ammoknights)
Billyfred is an unknown quantity at this point
In Range and Coerce?
Hello, for the mechinum wheel drive our team has set up, I have designed a control system using the joystick buttons. Unfortunately the design is clunky, and unwieldy. Because of this I have been looking at the "inrange and coerce" function. I was hoping to be able to use the joystick axises to replace the buttons (say moving a joystick to the left to make the mech drive go to the left.). Im confused with these things, has anyone used this idea to control the robot?
Unread 10-03-2010, 01:40
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: In Range and Coerce?
You'll find a premade holonomic drive system in Labview that will perform the drive functions you need without you programming them all from scratch. Take a look.
Unread 10-03-2010, 08:51
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
First, I'd recommend trying the canned Labview holonomic code. It may work better than what you're attempting right now.
However, if you're just trying to decide if the joystick is, say, 50% to the right or 50% to the left, in range and coerce is a bit excessive. You should just be able to use the "greater than" and "less than" comparators from the Boolean palette.
If you're trying to get a series of locations like, say "100%-75% Left", "75%-50% Left", "50%-75% Right", and "75%-100% Right", then a series of in range and coerce functions may be the simplest way to get that done.
range sensor elvin23 Programming 2 04-02-2008 20:40
Finding range DanDon Programming 11 10-01-2006 22:58
servo range of motion tux Control System 4 07-05-2005 02:32
Camera Range Finding russell Programming 9 31-01-2005 19:54
ir beacon range doy Programming 10 29-01-2004 16:46
