Go to Post if it was up to me, id just get one of those spinning BINGO things and do it that way - dodar [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 09-03-2010, 23:45
ajd ajd is offline
FRC #3238
Rookie Year: 2010
ajd will become famous soon enough
Measuring resistance using analog breakout
Our team is interested in using sensors that change the resistance of a wire based on an input. We read the datasheet for the Analog Breakout and it included instructions for reading a potentiometer, which has three wires, so that there is a constant resistance between the +5V and GND and a variable resistance between both (+5V and SIG) and (SIG and GND). But what if a sensor only has two wires, and simply adjusts the resistance between them? Do we wire +5V to SIG through the resistor, or SIG to GND, or something more complicated?
Thanks.
Analog Breakout l.li Electrical 5 12-02-2010 15:56
Analog Breakout Board EricWilliams FRC Control System 5 02-02-2010 12:16
Wiring analog breakout? excel2474 Electrical 5 31-12-2008 17:30
5 Amp Fuses for Analog Breakout & Solenoid Breakout finman Electrical 3 10-12-2008 11:59
measuring resistance via ADC ay2b Technical Discussion 1 27-03-2007 20:56
