Go to Post I think it's pretty cool that the Black Eyed Peas and other celebrities are willing to take up their time to come celebrate science and technology with us. - BIGWILLI2081 [more]
Unread 10-03-2010, 22:11
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Dashboard Recorder and Forwarder
This tool propably isn't ready for human use yet, but I want to get it out for people to try to use this week.
This tool allows you to record and playback dashboard data, and also forward that data to one or more machines.
What it is:
A small application which replaces the dashboard on the classmate. It forwards the data to one or more other devices, and records the data, including video.
Requirements
.net 3.5 on classmate
USB network adapter, connected to classmate
second computer for dashboard viewing
IP addresses as specified below.
Setup:
On the classmate navigate to "C:\Program Files\FRC Dashboard\".
Make a copy of all files in this directory.
Extract the contents of the attached ZIP to that directory.
Set the IP of the USB NIC on the Clasmate to 172.0.0.1, Subnet 255.255.255.0.
Set the IP of the second computer to 172.0.0.2, Subnet 255.255.255.0.
Configuration:
In the folder mentioned above you will now have a file "ForwardingGraph.xaml". Open it a text editor, and find the only instance the "10.0.0.2" replace it with you robot's IP address. It will be inthe form of 10.xx.yy.2.
Dashboard Modification:
In order to get a camera feed from the robot the following modification must be made to the dashboard.
In the block diagram of Dashboard Main.vi, within the camera processing loop, locate the block which says "Robot IP Address". replace that with a constant equal to "172.0.0.1", the DS's USB NIC's IP. Copy this modified dashboard to the Classmate as describde in other threads.
Playback
The playback mode is access by running dashboard.exe with the "/player" flag. There is a batch file included to start player mode. It will prompt for the location of the data.frcreplay file. The recording location is "C:\DashboardRecordings".
Where to get it
http://frc1103dashboard.codeplex.com...ses/view/41737
Eric Haskins KC9JVH
RS 232 and Dashboard Jake M Programming 6 06-03-2007 17:52
Set the TiVo/DVD Recorder, Sweet Engineering Special on Discovery 4/12 Joe Matt Chit-Chat 0 11-04-2006 20:33
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
C++ and Dashboard Matt_Gray Programming 6 04-06-2002 00:50
Dashboard Recorder Jim Zondag Technical Discussion 2 11-11-2001 18:13
