pic: Prototype Chassis
Re: pic: Prototype Chassis
well tell us what your machining capabilities are? Because I might consider lightening the Lexan if you have a mill or even a simple hole saw... but thats just me. Have you stress analyzed this at all?
Unless the bottom lexan is being used primarily to stiffen the frame, you could get away with a 1/8" lexan bottom to save weight you'd need for 3/8" lexan sides. Looks pretty cool! |
Based on this comment why not looking into building the chassis from baltic birch plywood. It is even lighter than lexan and in my opinion much easier to machine and assemble. Simple wood glue and brads/screws and you can have a chassis built in a couple hours. |
I will say the wooden chassis do look good if done proper.There are some tricks in the bag for 2011 FLR. (That is if I am able to stay on 3181 because of employment and because of the game) You will see a never before seen chassis arrive at FLR. )Last edited by Alex Cormier : 16-03-2010 at 13:02. |
| pic: FRC1293 Prototype 6wd Chassis | Thermal | Extra Discussion | 16 | 06-01-2009 23:12 |
| pic: 6wd prototype chassis | Collin Buchan | Extra Discussion | 7 | 03-01-2009 10:00 |
| pic: 6wd prototype chassis | Collin Buchan | Extra Discussion | 3 | 02-01-2009 14:14 |
| pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis | artdutra04 | Extra Discussion | 14 | 02-01-2009 02:11 |
| pic: 226 Off-Season Prototype Chassis | Matt Reiland | Robot Showcase | 2 | 01-02-2005 19:33 |
