Go to Post We have not always been a winning team but we have always tried to be a quality team. - WynS [more]
Unread 11-03-2010, 08:34
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Rookie Year: 2010
Itamar is an unknown quantity at this point
Wiring the fans
Hello,
I wanted to know how can I connect the fans provided in the kit.
Am I allowed to connect the fans directly to the PowerDashBoard? to victors? to spikes?
and if so, which wire goes to where, because I heard the connection is different than a PWM.
Unread 11-03-2010, 09:45
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Wiring the fans
Which fans?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 11-03-2010, 09:46
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Wiring the fans
The small fans in the kit are just 2 wires, +12VDC and Ground. You can wire them directly to the PDB.
The bigger fans have 3 wires. They are NOT PWM. They are +12VDC, Tach, and GND. The tachometer wire will allow you to measure the speed of the fan. In most FRC applications, this is totally unnecessary, and just supplying the fan with +12V and GND will be just fine. I believe the tach wire is the centre wire of the three.
Unread 11-03-2010, 10:05
Hodge1
Rookie Year: 1996
Re: Wiring the fans
Which fans? The compact fans can be wired directly to the input power terminals if ATTACHED to the Victor speed controller (R60). Otherwise, it would seem they fall under the motor rules, requiring a breaker-protected spike or speed controller to operate each one. This is strictly my opinion, and you can ask the GDC if you want an official answer. Anyone else is welcome to chime in.
Sweat the details
Unread 11-03-2010, 10:19
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
Team Role: Coach
Rookie Year: 2007
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Re: Wiring the fans
For sure the ones on the victors can be wired to inputs of the victors, but no other fans can do this. This is a great question for the GDC, my past experience tells me that you would be fine, but it would not be good to get to a competition and have them make you change it. Everywhere that motors are mentioned, they do not mention these, so that would say that they do not have to be connected to a spike to speed controller.
Unread 11-03-2010, 10:32
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Wiring the fans
There is no specific rule governing the fans, with the exception of the Victor fans, which may be attached directly to the power input terminals on the Victors.
That being said... In past years (which in no way applies to this year), this rule was absent. In its place, we had to connect the Victor muffin fans directly to the power distribution board, although we were allowed to join them all together under one 20A Spike. Teams impressed upon the GDC the safety and ease of connecting those fans directly to the Victor power inputs, and the rules were changed (starting in 2009, i believe... maybe even with a Q&A in 2008).
Using that as a precedence, i would think connecting the fans directly to the power distribution board would be acceptable (protected by a 20A breaker, of course).The fans are very low power devices, designed for moving air through an area with the intent of cooling components. Having them controlled by a spike defeats that purpose, unless the spike is triggered with a temperature sensor placed on the concerned components. Rather, having the fans on whenever the robot is on makes the most sense.
But that is all just my opinion. Please request clarification from the GDC
Is there a specific purpose for the fans included in the KOP? Damaku250 Kit & Additional Hardware 5 12-02-2010 07:46
Question about wiring Victor 884 fans. Thxe Electrical 12 09-01-2009 12:40
Wiring of Papst Fans aaeamdar Electrical 4 26-01-2008 01:21
Where do I hook up the victor fans? Excelsior Electrical 7 22-01-2006 21:19
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
