Hey everyone!!! Im from team 2121,
originally, we have only one joystick to do both drive and activate the pneumatic kicker. However, that has made the job more difficult because the driver sometimes can not concentrate on driving. So we decide to use the 2nd joystick for the pneumatic kicker. This is how I start Open.vi: joystick open (joy device - usp2) --> refnum registry set (refum name - joystick 2) Teleop vi: refum registry get( refum name - joystick 2) --> joy get --> button 1 Finish vi: refum registry get ( refum name - joystick 2) --> joy close However, it doesnt work. the robot doesnt respond when I press the trigger. Please let me know if there is anything wrong with this code. Thank you Team 2121 ![]() |
Re: How To program the second joystick?
It depends on what are you using to program, but in c++ our code is :
class: public { JoyStick *RightStick, *LeftStick; } Public: { RightStick = new Joystick (1); LeftStick = new Joystick (2); } and to program the trigger: if (LeftStick or RightStick-> GetTrigger()) Device->Set() (if this is any help for you ok!) Last edited by krudeboy51 : 11-03-2010 at 15:48. |
Can you post a picture of whats in your teleop?
From what you said, things to check would be: Make sure your ref names match EXATCLY (Spaces, periods, and so on..) Im pretty sure that device index starts at 0. Your first joystick should be 0, 2nd should be 1. Open up your dashboard, and go to one of the tabs that list joysticks. Make sure the one you want to be your second is right below your first (it switched up on me and drove me crazy for an hour) Last edited by Brandon_L : 11-03-2010 at 16:49. |
| How do you program joystick buttons in LabVIEW? | darkpheonix | NI LabVIEW | 10 | 13-04-2014 10:20 |
| How do I program a relay to turn on and off by pressing a button on the joystick? | eweathers | NI LabVIEW | 4 | 28-01-2009 22:34 |
| How to conect solenoids to the circuit board. and how to program it...??? | arpitshah | Pneumatics | 6 | 13-01-2008 15:06 |
| Does anyone have an idea on how to make a joystick program for an operating board? | necroprime | Programming | 8 | 09-11-2002 19:04 |
| Programming the second joystick in PBASIC | archiver | 2001 | 2 | 24-06-2002 00:25 |
