Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
Unread 12-03-2010, 13:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Caution - Burned out CIM blows Victor
Had a bit of an interesting happening with some Victors the other night. We discovered the hard way (3x over) that a burned out CIM motors can easily blow the transistors on the Victor, before the breaker to the input will ever trip. I suspect that when the CIM motors run for too long, they overheat, causing the insulation on the windings to degrade, thereby causing an internal short. When we disassembled the motor, it was all black inside. So, be careful with how long you run your robot for at a time during practice, and check the temp of the motors often, or you may find yourself replacing a Victor.
Burned out 2 5V regulators on Power Distribution boards jskene Electrical 5 13-02-2009 11:17
[FTC]: Caution - Tetrix Motors burn out on Stall ptan FIRST Tech Challenge 3 11-02-2009 10:19
Victor lights out of sequence matt99199 Electrical 4 10-02-2009 10:11
Wiring 2 CIM motors to one Victor ericsundbergva Motors 2 18-02-2008 10:12
Anybody else burned out? PMGRACER General Forum 52 18-01-2004 19:14
