Go to Post Honesty and integrity should always be taken seriously. It's the lubrication that makes the world go round. - rsisk [more]
Unread 03-12-2003, 16:26
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: If set screws suck . . .
Originally Posted by M. Krass
I've learned a lot over two years
too bad you werent around a little longer than that
ChiefDelphi Forums > Old Forum Archives > 2001 > What is your favorite method for attaching gears to shafts?
ChiefDelphi Forums > Old Forum Archives > 2001 > Connecting hub sprockets to shafts
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 03-12-2003, 19:03
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
I have been I just never had to do power transmission work until the 2002 season, so I never took the time to learn about it.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 22-12-2003, 19:19
PMGRACER's Avatar
PMGRACER PMGRACER is offline
Mentor
AKA: PAUL GIANNOSA
Team Role: Mechanical
Rookie Year: 2000
PMGRACER is on a distinguished road
We've attached gears manny ways in 7 yrs of competition, and the best way so far is by on e of 2 methods, 1) using a hex broach to put a "X" diameter hex in the gear and using a piece of hex stock on the shaft. Keep gear in place with a snap ring. 2) If no broach is a vailable then bore a hole in the gear and weld a "Craftsman" 7/16, 1/2" socket in place and use a apiece of hex on the shaft. Works extremely well and the gear is easily removed and serviced. Also used this "hex coupling" on the output of the trans unit to make it easy to separate the trans from the drivetrain for fast servicing. We could remove the trans in under a minute last season.
Racing is an incurable addiction!!
What was the best team set up? xavior06 General Forum 6 15-04-2003 23:16
AutoCAD Drawings Brandon Martus OCCRA 35 15-10-2002 11:33
Motor coupling archiver 2001 19 23-06-2002 23:35
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
