Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 13-03-2010, 03:44
matanost matanost is offline
FRC #1690
matanost is an unknown quantity at this point
activating a dashboard program on the DS
Hey guys I have a question: How can I make a Dashboard Program that I've built to work on the DriverStation?
any one can help?
Unread 13-03-2010, 04:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: activating a dashboard program on the DS
First I recommend renaming the default dashboard found in C:\Program Files\FRC Dashboard to Dashboard.exe.old
That way you will have the default dashboard to fall back on in case something gets messed up.
Then put your built dashboard file into the same directory as Dashboard.exe
QBASIC Dashboard Program Venkatesh Programming 14 12-02-2004 18:04
Dashboard Program LBK Rules Programming 5 12-08-2003 19:42
Dashboard Program archiver 2001 1 23-06-2002 23:30
miroboworks dashboard program? archiver 2000 3 23-06-2002 23:04
Dashboard Program archiver 2000 0 23-06-2002 23:00
