Go to Post These are the moments you will bring with you the rest of your life, enjoy them! - KathieK [more]
Unread 03-13-2010, 03:02 PM
chsrobotics3283's Avatar
chsrobotics3283 chsrobotics3283 is offline
FRC #3283 (Clarksburg Robotics)
chsrobotics3283 is an unknown quantity at this point
Labview and Java
Is there a way to convert Labview data into java? or java data into labview? this method can help us out a lot next year, if I can get a way to convert data. So that our team can use two programs interchangeably.
Unread 03-13-2010, 03:35 PM
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Labview and Java
If by "data" you mean source code, then the answer is no, not directly. LabView and Java are completely different paradigms. You can, however, possibly convert your program to psuedocode that can be translated to either java or Labview.
I don't need a signature.
Unread 03-13-2010, 08:33 PM
How do you do that?
Unread 03-13-2010, 09:36 PM
AKA: Dan
Psuedocode is just a simplified representation of a program that describes the logical flow of your code. Since programming is a logical exercise, meeting the requirements of psuedocode is achievable regardless of the actual programming language. Look here for more information:
http://en.wikipedia.org/wiki/Pseudocode
There is no magic way to generate psuedocode other than to write it. You will notice that examples resemble Java or C++ in form, however, the logic can still be applied to LabView.
CAN and Java MikeE CAN 3 02-18-2010 02:24 PM
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 08-31-2009 03:55 PM
Amazing Circuit Build and Simulation Java Applet Chris_Elston Electrical 2 06-26-2008 07:36 PM
Eclipse Plugin, Linux, and a Java Loader shtylman Programming 5 01-17-2008 02:44 PM
CMU Cam2 Java app (Help with Labview GUI) Team 1649 Programming 3 12-26-2006 02:25 PM
