Go to Post In real life, I use almost nothing I learned from football except that with a bit of hard work you can get somewhere. Oh, and I have bad knees on top of that. I could have (and wished I would have) learned that from a FIRST FRC team instead. - JesseK [more]
  #61   Spotlight this post!
Unread 18-03-2010, 17:50
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: The 469 auto
469 (or any other robot) parking in the tunnel does NOT cause another team to get a penalty. If a team can't get over the bump, they must have gone through the tunnel in the first place. When they did that, and if an alliance partner was already in the other team's near zone, that's when the penalty happened. It didn't happen when their escape route was blocked.
If one robot went over the bump and another through the tunnel at the same time, one of them had better turn around pronto. If the tunnel got blocked just after the transit, then the one who went over the bump has go get back.
(since 2004)
  #62   Spotlight this post!
Unread 18-03-2010, 18:31
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: The 469 auto
I believe the situation in question is that you were defending against 469 and they pushed you under the tunnel into the opponent area. The OP of this situation wanted to use this as a way to get 2 bots into the defense area legally
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
  #63   Spotlight this post!
Unread 22-03-2010, 10:03
greivousfan226's Avatar
greivousfan226 greivousfan226 is offline
Veteran
FRC #0226 (TEC CReW Hammerheads)
greivousfan226 is an unknown quantity at this point
Re: The 469 auto
The only sure way to beat a 217,469, and some other team alliance is to have a beastly defensive bot against 217and the other 3rd pick to block 217 and get balls to the home zone. The midfielder would basically pester 469 until the last 20 and your near zone is left open to your 3rd alliance partner to score.
  #64   Spotlight this post!
Unread 22-03-2010, 11:08
Chris is me's Avatar
AKA: Pinecone
Re: The 469 auto
Originally Posted by greivousfan226 View Post
The only sure way to beat a 217,469, and some other team alliance is *words*
If they win autonomous, you're done. 5 ball cycle isn't stoppable.
My plan for beating them involves not letting possibly the two best teams in the world pair up with each other.
  #65   Spotlight this post!
Unread 22-03-2010, 14:34
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Re: The 469 auto
If someone seeds higher than them (assuming they are on the same field), it is relatively easy to break up that alliance, isn't it?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
  #66   Spotlight this post!
Unread 22-03-2010, 14:50
AKA: Pinecone
Re: The 469 auto
I kinda hope someone gets "carried" just once now. Just to see if 217 + some other awesome teams can beat 469 + good but not great teams... Doubt it'll happen.
  #67   Spotlight this post!
Unread 22-03-2010, 20:01
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: The 469 auto
Hopefully, we'll take a run at this position at Troy (although we will certianly not be "carried")... it would be nice to seperate 217 and 469 for elims. Who knows crazier things have happened... .
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
  #68   Spotlight this post!
Unread 22-03-2010, 20:15
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Re: The 469 auto
Theres a fairly simple way to beat 469 and still be semi-productive in the game. 548 has the idea on how to do this, but were wondering how much effort its worth to be able to stop 1 team that we will see at states, and possibly no where else. By the way, I'm not gunna give away the secret incase we do end up using it...
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
  #69   Spotlight this post!
Unread 22-03-2010, 23:21
ExTexan's Avatar
ExTexan ExTexan is offline
Parent and Volunteer
AKA: Richard Singletary
FRC #0548
ExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant futureExTexan has a brilliant future
Re: The 469 auto
BJenks, try to get up to Troy Saturday and get a good look at some teams that 548 hasn't seen this year, as well as that 46something team. I'll be reffing as well as Mr. Bennett and Robert VanHam.
And it is my bet that there will be enough 469 and 51 copycats at States that we will have most alliances consisting of a ball handler (67, 33, 27, 910, 217 and the list is long), a diverter (469, 51 and the copy cats) and a diverter defense (548 and others that commit to that action). I can't imagine that any alliance that has to play against 469 will not choose a diverter defender as their first choice. The alternative is to let 469 lock in place and the game is over.
I also do not think that is the only time we will see a 469. I think Nationals will be the same as our States, maybe even more diverter heavy. I just can't imagine a picking alliance not wanting a diverter defender.
What we think, or what we know, or what we believe is, in the end, of little consequence. The only consequence is what we do.
2010 REFEREE: Kettering, Ann Arbor, Wayne State, Troy, MI Championship, Atlanta-Newton field, IGVC TARDEC, MARC and upcoming KETTERING Kickoff.
  #70   Spotlight this post!
Unread 23-03-2010, 07:27
Veteran
Re: The 469 auto
Well that's easier said than done. You basically have to be 1st overall seed to stop a 469/217 or similar matchup.
  #71   Spotlight this post!
Unread 23-03-2010, 17:37
Bjenks548's Avatar
AKA: Brendan
Re: The 469 auto
I'm not sugesting breaking up a pair like 469/217 or even 67/51. Theres just small modifications we can make to our bot to successfully stop them.
  #72   Spotlight this post!
Unread 23-03-2010, 21:22
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Re: The 469 auto
Now you got me curious... and trust me depending on how small it is, it'll be worth it.
  #73   Spotlight this post!
Unread 24-03-2010, 00:09
ExTexan's Avatar
FRC #0548
Re: The 469 auto
BJC, I wish all of my team would read your post. BJenks548 is right, we have the plan, the bot design and the capability to do it but we have a lot of team members that do not seem to understand how desirable it would be. We have not competed against 469 this year and none of our team has seen them so they don't understand, I believe. I truly think that every alliance that does not get 469 would pick a team that could keep 469 from completing their cycle.
And I also agree with BJenks, we know how to do it, we can do it, and I believe we will be playing well up into the elimination matches at both States and Nationals if we do it. Time will tell!
  #74   Spotlight this post!
Unread 24-03-2010, 01:35
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Re: The 469 auto
if a team with a kicker that recharged fast enough could sit in front of them, then they could just kick the balls out as soon as they were deflected out, our kicker has a recharge of 1.2 secs at min, 1.8 at max, so i don't think that would be too difficult to do.
  #75   Spotlight this post!
Unread 24-03-2010, 01:40
davidfv davidfv is offline
FRC #0399 (Eagle Robotics)
Team Role: Tactician
davidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant future
Re: The 469 auto
Originally Posted by Nuttyman54 View Post
link still doesn't work...
469's strategy is brilliant, because in order to stop them you have to not only prevent them from getting to the tower first.
I wonder if you get to the tower first will they still expand, hence a possibility of a penalty?
Davidfv
Mentor/Drive Coach
Using auto cad for the autodesk inventor competition [527]phil Inventor 7 18-01-2006 10:41
Creater of the DeLorean auto dies Jay H 237 Chit-Chat 4 23-03-2005 12:54
Ruling for what defines being at the auto-loader Andrew Schuetze Rules/Strategy 4 15-01-2005 22:41
Team 469 and the Gyro archiver 2001 0 24-06-2002 02:57
Team 469 is the coolest!!! yystickers Off-Season Events 0 19-11-2001 14:51
