Go to Post Rules from prior years DO NOT APPLY to this year! - dlavery [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations > The Blue Alliance
Unread 14-03-2010, 18:44
Chris is me's Avatar
AKA: Pinecone
[TBA]: No Elim Ties on TBA?
I noticed that for my team's performance at WPI, neither 3-3 tie was listed in elims, and the scores for QF2-4 and 2-5 were in the spots for QF2-1 and 2-2 (where the ties go). Is this a bug or feature? Can it be fixed?
Unread 14-03-2010, 18:55
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Re: [TBA]: No Elim Ties on TBA?
I believe TBA just scrapes data from the FIRST results page, which doesn't appear to show those matches either. http://www2.usfirst.org/2010comp/eve...chresults.html
Unread 14-03-2010, 19:38
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Technically the 4th amd 5th match are replays, thus the ties are not officially recognized.
- Arizona North
Unread 19-03-2010, 06:36
GaryVoshol's Avatar
Happy Birthday! GaryVoshol GaryVoshol is offline
Cogito ergo arbitro
Rookie Year: 2000
That's right, it's a feature of the system, based on the way the tournament rules are written:
Originally Posted by 9.4.3
In order to allow equal time between matches for all ALLIANCES, the order of play will be:
QF1-1, QF2-1, QF3-1, QF4-1,
Then QF1-2, QF2-2, QF3-2, QF4-2,
Then QF1-3*, QF2-3*, QF3-3*, QF4-3*
Then any QF replays due to ties*
Then SF1-1, SF2-1, SF1-2, SF2-2, SF1-3*, SF2-3*
Then any SF replays due to ties*
Then F-1, F-2, F-3*
Then any F replays due to ties*
(* - if required)
(emphasis mine)
If you look at the match results for an event, you will see that QF1-1 is listed as being played after QF1-3, when the QF goes to more than 3 matches. However if QF-1 is a tie and then QF-2 and QF-3 are won by the same alliance, the tie result is shown.
(since 2004)
Unread 19-03-2010, 14:11
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
FRC #0254 (The Cheesy Poofs)
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Speaking as a scorekeeper, tied matches in the eliminations are treated as replays in FMS. We're supposed to note the ties and forward the information to FIRST after the event so that they can later update the results page manually, at which point I assume TBA would be able to pick them up.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 19-03-2010, 00:57
Greg Marra's Avatar Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
no team (The Blue Alliance)
Team Role: RoboCoach
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
This is correct. We can't get more information than FIRST publishes.
Formerly Bobcat Robotics - Team 177 and X-Factor - Team 2124, now The Blue Alliance
[TBA]: TBA API info on FIRST Wiki Greg Marra The Blue Alliance 3 01-03-2011 15:40
[TBA]: [TBA]:2008 Colorado Reigional Video's bobwrit The Blue Alliance 2 24-01-2009 21:34
[TBA]: TBA API ActiveX Control Shadow503 The Blue Alliance 2 10-04-2008 08:59
[TBA] Sumbit your Robot Photos on TBA lynca Robot Showcase 0 11-03-2008 13:25
[TBA] TBA Presents... Soldering and Multimeter Tutorials Greg Marra General Forum 0 27-01-2007 20:15
