Go to Post Think about the other teams...today your opponent, today your teammate. - Al Skierkiewicz [more]
Unread 15-03-2010, 22:25
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Digital Sidecar GPIO output states?
Question for cRIO hardware experts or gurus:
What are the two states of the "signal" pin of the GPIO on the Digital Sidecar when operating in output mode?
is it power/ground? or power/float? or ground/float?
is it programmable? and if so, does the FRC LabVIEW installation have a VI that fully supports all three modes above?
Thanks.
Unread 15-03-2010, 23:29
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Digital Sidecar GPIO output states?
It is power/ground. Switching to high impedance takes significantly longer, and is therefore not recommended (not supported?)
If you want ground/float, the i2c pins have the necessary FET to do so. I don't know if you have arbitrary control over them.
Unread 16-03-2010, 00:23
Ether's Avatar
Rookie Year: 1969
Originally Posted by EricVanWyk View Post
It is power/ground.
So, you could hook that power/ground GPIO signal directly to, say, pin 2 of JP1 (BRAKE EN) on the Jaguar to control BRAKE/COAST... No need for an external pull-up resistor, yes?
crio dashboard GPIO output darkorbit Programming 8 09-02-2010 15:29
Using a GPIO pin for both input and output. Shinigami2057 C/C++ 6 24-02-2009 20:04
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
