Hello everybody,
There is a new version of Jaguar and Black Jaguar firmware; version 90. The new files are up on http://www.luminarymicro.com/jaguar. Jaguar-90.bin BlackJaguar-90.bin This version fixes a bug in Speed Control Mode for both Gray and Black Jaguars. This bug makes the PID function behave differently in reverse than in forward. For example, you can tune your PID constants to where it holds speed stably in the forward direction but when you change over to reverse, the control loop is no longer stable. It is possible to have PID constants that work for both forward and reverse, but the bug makes it difficult. Version 90 fixes this bug so that the PID operates the same in forward and in reverse. This bug is only in Speed Control Mode. Therefore, if you are not using that mode, you do not have to update your firmware. Good luck in Week 3! -David |
Re: New Jaguar Firmware: Version 90
We are seeing differences in forward vs reverse directions while using current control mode. Is this a related issue?
Thanks for spotting it! -David |
| New Jaguar Firmware: Version 89 | dyanoshak | CAN | 10 | 24-02-2010 10:10 |
| Bricked black Jaguar after bad firmware update | FRC4ME | CAN | 13 | 19-02-2010 16:52 |
| Black Jaguar Not Taking New Address | duane | CAN | 1 | 06-02-2010 19:55 |
| New version of FIRSTclipse: 0.0.3 | Astronouth7303 | Programming | 8 | 18-02-2007 21:06 |
| New version of WPILib | BradAMiller | Programming | 26 | 27-01-2007 15:49 |
