Go to Post [*]"Dewtoxification" is a real plague among teenagers. - JesseK [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 18-03-2010, 00:26
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
LM_API_CFG_NUM_BRUSHES
On this page of the firstforge site (May require login) :
http://firstforge.wpi.edu/integration/viewcvs/viewcvs.cgi/CANJaguar%20for%20Java/src/edu/wpi/first/addons/JaguarCANProtocol.java?root=canjaguar&rev=9&system =exsy1002&view=markup
There is a line :
Code:
public static final int LM_API_CFG_NUM_BRUSHES = (LM_API_CFG | (0 << CAN_MSGID_API_S));
If we tell the jaguar how many brushes our motor has, could we use the motor's brushes as a simple tachometer so that we could do closed loop (somewhat) speed control without adding additional sensors (encoders, potentiometers, etc.)?
edit:
And if this could be used, how many brushes do the CIMs have?
If this could be used, would this work for a speed reference (or even position)?
Code:
    public static class SpeedReference {
        public final byte value;
        static final byte kEncoder_val = 0;
        static final byte kBrush_val = 1;
        public static final SpeedReference kEncoder = new SpeedReference(kEncoder_val);
        public static final SpeedReference kBrushes = new SpeedReference(kBrush_val);
        private SpeedReference(byte value) {
            this.value = value;
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 27-03-2010, 00:07
biojae's Avatar
Re: LM_API_CFG_NUM_BRUSHES
So, the banebots RS-555 has 5 brushes. If I had a jaguar on the CAN bus, could the brush count be used for either the Position or speed control mode?
would something like this work?
Code:
public static class PositionReference {
        static final byte kPotentiometer_val = 1;
        static final byte kBrushes_val = 2;
        public static final PositionReference kEncoder = new PositionReference(kEncoder_val);
        public static final PositionReference kPotentiometer = new PositionReference(kPotentiometer_val);
        public static final PositionReference kBrushes = new PositionReference(kBrushes_val);
        private PositionReference(byte value) {
            this.value = value;
public void configMotorBrushes(short brushes) {
        byte[] dataBuffer = new byte[8];
        byte dataSize;
        dataSize = packINT16(dataBuffer, brushes);
        setTransaction(LM_API_CFG_NUM_BRUSHES, dataBuffer, dataSize);
CANJaguar brushedDCMotor = new CANJaguar(2, ControlMode.kPosition);
brushedDCMotor.setPositionReference(PositionReference.kBrushes);
brushedDCMotor.configMotorBrushes(5);
brushedDCMotor.enableControl(0.0);
