Go to Post I think FIRST is probably close to the farthest you can get from 'gangsta', outscored only by the math team. - Tom Bottiglieri [more]
Unread 18-03-2010, 18:38
eedo369 eedo369 is offline
FRC #3088 (Kill-O-Bites)
Rookie Year: 2010
eedo369 is an unknown quantity at this point
What is a Cypress?
Hello everyone,
I know this may sound a bit too late but I wanted to ask what exactly is the Cypress, what can I do with it and how does it work?
Unread 18-03-2010, 19:19
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Re: What is a Cypress?
Well here in the south, a cypress is a tree that grows in the swamp. But I doubt that is what you mean.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 18-03-2010, 19:27
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
It is an electronic board that came in your KOP, also called a PSoC. You can connect it to the USB port of your Classmate and configure what I/O options you want. Then then you can program your cRIO to can read analog and digital I/O from switches etc, connected to the Cypress
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 18-03-2010, 19:28
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
You can read more about it here.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 18-03-2010, 19:34
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
There is a nice enclosure for the board which you can get here, if you would like a protective box and nice headers to wire to.
Unread 18-03-2010, 20:58
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
Team Role: Mechanical
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
You can do cool things like put switches on it to tell the robot which zone it is starting in so it can use the right autonomous code......that is if there is time to program different autonomous
Rob Self-
Cyberhawks Team 706
Hartland, WI
Our breakaway bot in action (13-3-1): Team 706 in action
Unread 18-03-2010, 21:44
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You can do more than that - You can build a whole custom control box for your operator (although I recommend against using it for the driver, simply because the driver needs two joysticks or a gamepad to drive)
Kettering Motorsports
Unread 19-03-2010, 01:00
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
You can have joysticks on the PSoC since its got ADC capability. You just have to use joysticks similar to the ones included in the kit 2008 and earlier.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 19-03-2010, 05:53
Rookie Year: 2010
Thanks for all the info!
Can you tell me how to program it and and how to use Labview to program the CRIO to read it?
Unread 19-03-2010, 13:43
apalrd's Avatar
More Torque!
VRC #3333
To program the PSoC: Plug it in to USB (no battery needed) and open PSoC programmer. Find the file called FRC_IO_v2.hex, located in Shared Documents on the Classmate. Upload the image.
On the other end - Go to WPI Robotics Library => Driver Station => Extended IO for the extended IO. This includes VI's to read analog channels, digital channels, and write digital outputs, plus much more.
Unread 19-03-2010, 14:05
Rookie Year: 2010
O.K. Let's say that I want to use the Button on the Cypress to determine which autonomous I want to use right before the match starts.
How do I do that?
The problam is, I don't know how to "connect" what I see in Labview to what I see on the board. And our electrician hasn't got a clue on how to connect DIOs and PWMs etc to it.
Cypress Board Source lynca FRC Control System 1 03-02-2010 01:32
Cypress Board Issues kgzak FRC Control System 4 02-02-2010 18:40
Cypress board LAYOUT SteveD FRC Control System 11 23-01-2010 11:23
Cypress board bls0620 Electrical 4 17-01-2010 23:22
Cypress soc? sp33chy FRC Control System 2 15-01-2010 08:58
