Re: Advanced tools in the workshop (Mill, Lathe, Welder etc.)
I am a machinist on my team, and I would like to put my input in on what the most valuable tools are and what is used the most:
1. Manual Mill- Allows for accurate parts to be made, which is vital in competition. 2. Belt Sander- Keeps manufactured parts safe! 3. Lathe- Crucial for a custom and reliable drive system. 4. Bandsaw- Makes for quick raw material manufacturing. |
TIG welding is practical on site, we do our TIG welding in the
school shop. It is essential to have a experienced TIG welding mentor available, but TIG welding of aluminum can be picked up by students with close guidance from a mentor. The smallest welder would be a 250 amp unit, the smaller 175 amp units are stretched a little too much for some situations involving 1/8 aluminum and can't deal with anything thicker. |
We do almost 100% of the robot in house. Assuming you already have a cordless drill and a drill press; here's how I'd rank our advanced tools...
1. Metal Chop Saw is probably our most used tool. http://www.amazon.com/Porter-Cable-1.../dp/B0000222X3 2. Disc / Belt Sander is a must as well, and get extra sanding discs and belts. http://www.amazon.com/708598K-JSG-6C.../dp/B00005NMRO 3. Tig Welder would be next, as others have said, 150 Amps minimum http://www.denlorstools.com/home/dt1...hob500425.html Accessories would be 2 Argon tanks (one always runs out on the most important day!), 2-3 helmets, gloves, electrodes, extra ceramic torch ends, filler and a nice flat metal table. 4. Vertical Band Saw, 14" is good. Get extra blades. Local hardware stores usually only carry blades for cutting wood. So be sure to get blades that are 1/4" or so wide and have 12-18 Teeth per inch. http://www.rockler.com/product.cfm?page=21646 4. Manual Mill... The 3-1's are iffy and would not recommend them. As others have stated, half the money goes to the machine, the other half to the tooling. DRO is so helpful. Our has a DRO retrofit which works just fine. 5. CNC Benchtop Mill... We use a CNC Jr. from CNC masters, and there are others as well for ~$10-$20,000. Don't retrofit your one and only manual mill. Once you have a manual mill and all the tooling, you don't have to go get more tooling for the CNC mill. BUT you should figure in the cost of software. We use MasterCAM which is AMAZING. 6. Arbor Press and a set of broaches (keyway and hex). http://www.dumont.com/prod2c.html http://www.google.com/products/catal...wAA#ps-sellers 7. Lathe... We have a small benchtop lathe to turn down shafts and such. Unfortunately it doesn't allow us to deal with things larger than an inch. We rarely use the lathe. |
for some of the better funded teams out there the plasma cam could be something to expand your workshop. It costs about $9,000 for a low end model to $25,000 for the high end models. Sadly my team does not own one, so i can't give a personal review but it seems like it could be something pretty handy for a robotics team.
| [OCCRA]: OCCRA OCT-NE 10/14/09 Advanced Workshop PDF | marccenter | OCCRA Programming | 2 | 07-12-2009 13:56 |
| Drill/Mill or Lathe/Mill attachment for small shop area | Coach Norm | General Forum | 22 | 16-09-2009 15:59 |
| lathe turning wheels- is it against the rules? | mrnoble | Rules/Strategy | 6 | 22-01-2009 19:21 |
| EMC linux + CNC mill + CNC Lathe | Leav | Technical Discussion | 8 | 09-11-2008 23:08 |
| Where can I find lathe and fillet tools in 3DS Max? | laungani26 | 3D Animation and Competition | 2 | 16-01-2007 16:34 |
