Go to Post We don't do battle bots, but we play hard. - Gdeaver [more]
Unread 20-03-2010, 14:01
ewoodring ewoodring is offline
AKA: Eric
FRC #2474 (Excel)
ewoodring is an unknown quantity at this point
Autonomous independent-watchdog errors
I am programming in LabVIEW for autonomous independent. I have a button on the joystick that toggles autonomous on and off in disabled mode. When I deploy code and enable autonomous, I get error messages in the message window in the Diagnostics tab on the Driver Station that say "Watchdog expired: system #, user #." Is there anything in code I have to change to fix this? Thanks.
Unread 20-03-2010, 16:36
Brandon_L Brandon_L is offline
doot doot
AKA: Brandon Liatys
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Re: Autonomous independent-watchdog errors
can I see the code for your toggle?
I don't have lab view on this PC so it would have to be a screenshot.
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
Back for 2017!
Unread 20-03-2010, 20:19
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It depends.
A few of these messages are normal and may not affect your robot operation.
The # is a count of how many of each have occurred and of which type of Watchdog (system vs. user).
  • You'll usually see momentary system Watchdogs at mode transistions, e.g., Disabled -> Auto -> Teleop -> Disabled. Those are nothing to worry about.
  • User Watchdogs are common when your autonomous code finishes and exits, but seeing them in Teleop or while Auto is supposed to be running is a problem in your code.
In the lower left of the Driver Station screen are you seeing a persistent message of "Watchdog not Fed?"
That message will occur if you are not currently running any autonomous code at all, for instance, if it has already completed and exited or if you have bypassed all auto code. The default Autonomous Independent will generate this Watchdog, since after it completes it's assignment it just exits and the Watchdog goes unfed.
The Watchdog message is not a problem if no code is supposed to be running.
In this case, when Teleop code begins to execute, it will resume feeding the Watchdog and the message will go away.
periodic tasks in autonomous independent Ether NI LabVIEW 19 31-03-2010 07:15
global variables and autonomous independent Team1824 NI LabVIEW 10 19-02-2010 23:00
Autonomous Mode, Independent, Iterative (?) FRC2669_Valery General Forum 4 18-02-2010 09:50
Autonomous Independent Code Issue Watchdog not fed pilum40 FRC Control System 0 11-02-2010 12:00
Using Sensors in Autonomous Independent Felipe Sagui NI LabVIEW 2 27-01-2009 17:25
