Go to Post We've been thinking about just declaring our smallest kid on our BOM and making her part of the robot. - Qbot2640 [more]
Unread 21-03-2010, 03:21
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Swapping digital input/output
I have a sensor which I would like to use which requires swapping a pin between input and output. Basically you set the pin to output/high, charge a capacitor, then set it to an input and time how long until the input reads low. Is there an easy way to do this with WPILib?
Based on my reading of the code, the current objects do not allow swapping the direction of a DIO pin. To change this would require modifying the DigitalModule class, probably cloning the AllocateDIO method to make a SetDIO method which would call m_fpgaDIO->writeOutputEnable to change the direction. Next I'd probably want a wrapper class which combines the DigitalInput and DigitalOutput classes. Finally I'd want a class similar to (or perhaps actually using) the Counter class which would have an interrupt on the falling edge to stop a timer which gets started on direction change.
Does this sound like the right track? Am I missing anything? Is there an easier way to do this? Has anyone else done this already?
Thanks.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 21-03-2010, 03:52
ay2b's Avatar
AKA: Andy
FRC #2928
Rookie Year: 1994
Re: Swapping digital input/output
I just thought of this:
Maybe the Ultrasonic class, two I/O pins and a diode would solve the problem: Charge the cap through a diode from an output pin. This corresponds to the "ping" in the Ultrasonic class. When the output pin goes low, the diode prevents the cap from being discharged by the output pin, and the input pin can be used to measure the discharge rate.
Thoughts?
Unread 21-03-2010, 17:32
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Thoughts?
Sounds like you are on the right track to me. Personally, I'd use a FET instead of a diode to eliminate the .6V, but it likely doesn't matter.
Out of curiosity, what sensor are you using? Datasheet link please!
Unread 21-03-2010, 14:21
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Last year, switching I/O directions caused a delay in all DIO. See http://forums.usfirst.org/showthread.php?t=10460
Not sure if anything changed for this year.
DS Digital Input/Output dboisvert C/C++ 11 08-03-2009 17:50
Digital Input? boris C/C++ 1 30-01-2009 14:51
Switch digital input to output during operation? Parallax Ultrasonic wt200999 C/C++ 2 28-01-2009 19:30
live input/output to/from application MarkH Programming 3 06-04-2006 01:43
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
