Go to Post I respect what you have to say and I ask that you do the same for me. - Andrew Schreiber [more]
Unread 21-03-2010, 18:01
ricechrisbtreat ricechrisbtreat is offline
Chris Barlog
AKA: Chris Barlog
FRC #2659 (Robo-Warriors)
ricechrisbtreat is an unknown quantity at this point
Question Help with timing
I just have a quick question. How can I get a part of the robot`s code to start one or two seconds after another part finishes? I'm a noob when it comes to timing in labview. Thanks in advance.
Thank you teams 207 and 973 for picking us on your alliance and allowing us to win the L.A. Regional!
Unread 21-03-2010, 18:10
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Help with timing
Several ways:
You can tie the two actions together through a Time Delay vi (Programming -> Timing palette)
You can use a flat sequence structure (Programming -> Structures palette)
You can use a State machine (http://frcmastery.com/try-me/state-machines/)
You'll want to use a State Machine if you're implementing this in Teleop.
The others can be used if this is a stand-alone task that can be independently implemented in Periodic Tasks.vi
Need help with timing auton IndySam NI LabVIEW 6 09-03-2010 00:26
Issue with Solenoid Timing. VI Included. robotic321 NI LabVIEW 5 11-02-2010 16:19
Timing with the Driver Station Zorkinian Programming 6 10-01-2009 09:42
HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! drewjones13 Programming 1 17-01-2008 20:52
Help needed timing a pulse (2004 Robovation) Josh Siegel Programming 18 22-11-2006 12:07
