Go to Post There are always going to be tough calls, and you just have to trust in your officials to do the right thing. - Jeff Waegelin [more]
Unread 03-21-2010, 10:06 PM
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
Servo control with a joystick
Hello.
My team wants me to get a servo rigged to be controlled with a joystick. How do I convert joystick values (-1 thru. 1) to servo values (0 thru. 1)?
Unread 03-21-2010, 10:33 PM
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Servo control with a joystick
Use the Servo class.
It has two methods you can use:
set(double value) where value = 0.0 to 1.0 for full range of motion
setAngle(double degrees) where degrees = position of the servo...values in excess of allowable range of motion simply saturate to the servo limit. The API assumes that the kit servos are linear.
So to answer your question. Since the joys run from -1 to 1, you can simply use a multiple for the set method:
Code:
Servo servo = new Servo(1);//Servo in PWM port 1
double servoIn = (joy.getX() +1)*0.5;
// Command to servo
servo.set(servoIn);
That should do it.
I don't need a signature.
Unread 03-22-2010, 02:00 AM
FRC4ME FRC4ME is offline
FRC #0339
Rookie Year: 2007
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
FYI, the general formula for scaling one range of values to another is:
Code:
newValue = newMax + (newMax - newMin) * (oldValue- oldMax) / (oldMax - oldMin)
In this case, oldMin and oldMax are -1 and 1, respectively (the joystick range), while newMin and newMax are 0 and 1, respectively (the servo range).
Go directly to queue. Do not pass pit.
Unread 03-22-2010, 08:02 PM
1 * 4 != 14
Rookie Year: 2007
Thanks!
Just to verify:
Code:
    public double convert(double input) {
        //newValue = newMax + (newMax - newMin) * (oldValue- oldMax) / (oldMax - oldMin)
        input = 1 + (1 - 0) * (input- 1) / (1 - -1);
        return input;
Unread 03-23-2010, 09:04 AM
AKA: Dan
Originally Posted by Robototes2412 View Post
Thanks!
Just to verify:
Code:
        return input;
You can verify it by plugging in your input extremes (-1 to +1). I haven't had my coffee yet, but it doesn't seem like -1 converts to 0. Why not try the one I posted? KISS
Unread 05-09-2010, 07:31 PM
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Team Role: Coach
Rookie Year: 2007
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
I'm probably REALLY late to the party, but here's the solution I was taught.
double servOut = (stick.getRawAxis(1) + 1) / 2;
-1.0 becomes 0 and +1.0 becomes 1.0
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Problem with servo control Jake The Man NI LabVIEW 2 02-09-2010 11:23 PM
Joystick-Servo control Lumit NI LabVIEW 1 02-08-2010 11:21 PM
Camera servo control off of the Joystick axes m3rc1l3ss NI LabVIEW 5 03-13-2009 08:00 PM
We need help with joystick control Team ICE #1611 Control System 4 01-24-2005 03:57 PM
how do i control a piston with a joystick Ryan Foley Programming 2 05-27-2003 05:13 PM
