Go to Post Actually there are several Wayne Cokeleys circulating around. We cloned him in 2001. This is his evil twin Mordechai responding.....-WC 3 - Wayne C. [more]
Unread 21-03-2010, 22:30
mbone206 mbone206 is offline
FRC #0223
mbone206 is an unknown quantity at this point
Tank drive Labview autonomous
We are running tank drive and allocating PWMs in Begin.
In Autonomous, having trouble setting speed with constants in tank drive (putting constants on tank drive VI). Also tried setting speed with constants in Arcade also, not workking. Can only work when use 'Open Motor and Set Speed VI' from Motor Control VIs in Autonomous. Do not think Watchdog is problem, tried adding feed watchdog.
Any help is greatly appreciated
Mark
Unread 22-03-2010, 15:30
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Tank drive Labview autonomous
One simple thing that can explain your problem is a mismatch between the drive motor names fed to the Refnum Set vi in Begin and the Refnum Get in Autonomous. Can you make absolutely sure that you don't have any upper/lowercase differences, or any extra spaces anywhere in one of them?
Unread 26-03-2010, 22:21
FRC #0223
Working...
It was something as simple as increasing motor setting, still not sure why...
Alan, thank you for reply...
How do I do tank drive in labview 2010 Bluedog24 NI LabVIEW 3 09-02-2010 02:31
We're in tank drive labview he#$ mutantblond NI LabVIEW 7 01-02-2010 16:59
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
Tank Drive with Advanced Framework in Labview finman NI LabVIEW 4 30-01-2009 13:35
Please Help, Don't Know How to Implement Tank Drive in LabView CVassos NI LabVIEW 5 24-12-2008 16:55
