Flash drive
I would love to be able to bring a flash drive to pit admin and get the match schedule in excel format. That would make my life easier.
Re: Flash drive
Rather than by handouts, that would be great!
I know a few years ago BMR tried providing a wireless setup so you could see the match list, but I haven't heard of a system since that was provided by the regional. I also liked the digital transfer of the BOM this year. Is there any way we can go more digital? |
Re: Flash drive
On Friday morning go to http://www2.usfirst.org/2010comp/eve...chresults.html (replace XX with your event code). You can copy and paste the contents into excel.
edit: you have to copy it into note pad and then excel. Last edited by ATannahill : 22-03-2010 at 16:27. |
Re: Flash drive
Re: Flash drive
Remember to attach it with a string to something. Those things disappear quickly, if you know what I mean :/
Re: Flash drive
It would be nice if FIRST officially adopted the (now open-sourced) Sundial and incorporated it into the Field Management System, and hosted it on an official Wifi network separate from the 802.11n used for the field control. It would be especially helpful if they they incorporated a mobile-device optimized version of the web page.
Not only would it make it so much easier for teams themselves, but queuing would get a lot easier as well. The FRC Spyder and FRC Tracker apps are great if you have a phone with a data plan, but otherwise everyone else (iPods, laptops, etc) is out of luck. |
Re: Flash drive
Re: Flash drive
Match schedules are generated by FMS and then sent to a PDF for printing. It seems that an "export to excel" could be added to the FMS schedule generation. I'll suggest it to the FMS designer and see what can be done. Logistically the biggest thing will be providing a computer to Pit Admin. Right now the FIRST electronics case doesn't include a laptop for Pit Admin.
Re: Flash drive
Once they post it on the website, you can use a feature of excel called "web query" to automatically import it for you. This link explains how to use it:
http://www.homeandlearn.co.uk/excel2...l2007s8p5.html |
#10
Re: Flash drive
i 2nd the sundial idea. FIRST seriously needs to adopt the system. |
#11
Re: Flash drive
If first got away from offf the shelf wifi and went lisenced bad sundial would work flawlessly and the matches would run flawlessly without outside interference.
#12
Re: Flash drive
Re: Flash drive
I have a iPhone and FRC Spyder. Does it only work on a DROID?
| Flash Drive Error | aksimhal | Chit-Chat | 7 | 30-12-2008 12:40 |
| flash drive | tseres | IT / Communications | 20 | 13-06-2007 16:05 |
| How would I interface a flash drive to the RC? | JBotAlan | Technical Discussion | 42 | 31-01-2007 15:24 |
| MPLAB on USB flash drive | ultramrw21 | Programming | 3 | 25-01-2005 21:20 |
| Flash 6 | Adam Shapiro | General Forum | 4 | 23-12-2002 15:19 |
