Go to Post my original intention were that the 5 of them were the power rangers, but then i thought of Copioli as the Pink Ranger and laughed... a lot - Mike Schroeder [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-03-2010, 23:52
blayde5's Avatar
blayde5 blayde5 is offline
AKA: Abhi
FRC #3504 (Girls of Steel)
blayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of light
AndyMark Plaction Wheels
http://www.andymark.biz/am-0514.html
My team has started using these wheels this year and for the most part we get good performance out of them.
However we've noticed that AndyMark joins the treads with staples. During both of our competitions we've found the treads to start coming off and during one of our matches at SVR, the tread actually did come off.
To solve it we just riveted the ends of the tread and it seems to work okay.
Any other teams using these wheels have the same issue?
Unread 22-03-2010, 23:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: AndyMark Plaction Wheels
Pretty much all the teams I've talked to have the same issue.
They use one of two solutions:
1. More, bigger staples to keep the ends together
2. Rivet the tread to the wheel.
Unread 22-03-2010, 23:55
Chris is me's Avatar
AKA: Pinecone
This happened to us too. I kinda expected it to happen. Riveting on the tread was one of those things we kept putting on the list of things to do, but never did.
Two rivets per wheel did the trick. Everyone should do this always.
Unread 22-03-2010, 23:57
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Rookie Year: 2007
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
if it comes off at a competition a drill and a zip tie does the trick as well too.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 22-03-2010, 23:59
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
This happened to us, too. Same issue, same solution.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 23-03-2010, 00:00
AKA: Pinecone
If you're already drilling the hole, why not rivet it? If you need a hand pop rivet gun, you can borrow my team's gun.
Unread 23-03-2010, 00:37
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
We had the treads come off during light testing just prior to ship.
We riveted, but the treads came loose again.
We solved the problem with a method identical to how
we used to make good wheels from KOP wheels. We cut
the flanges off and then sanded the rims using a belt sander
right on the robot. We usually use a lathe for this, but we
did not want to take 8 wheels off the robot at this point.
We made our own treads using incline belting from McMaster,
by carefully sanding the first layer of nylon off the backing,
just exposing the black rubber layer. We then cut the treads
and glued them on the wheels with mid-cure crazy glue, using
no rivets or screws, after cleaning the tread and the rim with
MEK (or acetone if you don't have MEK handy).
No tread came loose at SVR. When we rip a tread off of one
of these wheels, it leaves the black rubber from the tread on
the wheel rim all the way around. Screws or rivets are not
needed at all when using this gluing procedure. In the rare
event that a tread does start to peel we use some glue on
it and it rarely starts to peel again.
Eugene
Unread 23-03-2010, 01:43
mahumnut's Avatar
mahumnut mahumnut is offline
FRC #1418 (Vae Victus)
mahumnut is an unknown quantity at this point
our team trimmed the tread itself because it was overlapping the raised edges of the wheel, we then used rivets. After the DC regional, we ordered their aluminum version because the plastic ones kept on breaking when our robot went over the hump. Because our robot was 6 wheeled, the hump wasn't the smoothest trip crossing the zones.
Unread 23-03-2010, 02:33
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
Rookie Year: 2010
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
We hit this issue in the hour before shipping the robot. (We also sheared the bolts off one of the drive wheels and noticed the other drive wheels bolts were bent, but that's another story...).
We tried holding it on with tape just so we could practise prior to shipping, but it kept slipping out.
We had some spare wheels, so we changed them out at GSR prior to competition. These lasted a while (I think we were being careful) but by the end of Friday we had lot a tread again. We got it back together for Saturday, but lost the tread again in the next match.
Prior to crating it ready for Atlanta, we managed to get a couple of wheels ready, using contact glue on the tread AND rivets. Hopefully this will hold. Otherwise I'll either cry or just go home.
Ok, maybe not.. it's a long flight..
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 23-03-2010, 06:54
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
When you add screws or rivets, be sure to make them slightly off of the centerline of the wheel.
These wheels are molded plastic, and the seam is right in the center. By moving slightly off to each side, you are staying in stronger material.
Advice straight from the "manufacturer", so to speak.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 23-03-2010, 07:22
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Same problem; same solution.
Unread 23-03-2010, 07:28
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Our Plaction wheels still have the standard staples from AM in them, and we haven't had any problems with them... yet.
*Scrambles to pack Rivet Gun and Rivets for next event*
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 28-03-2010, 08:48
jfc358 jfc358 is offline
FRC #0358
jfc358 is an unknown quantity at this point
Angry Re: AndyMark Plaction Wheels
Has anyone else had problems with cracking of this wheel? We lost an entire segment of the rim, spoke to spoke, on one wheel yesterday and had to splint cracks in another. This appears to be happening when going over bump. Cracks seem to form on outside of facing side of wheel first and then propagate through wheel. Since the robot never comes down off of the bump completely square to the floor, the outside of one rim takes more of the impact. This is what we think is causing wheel to crack. At least that is what appears to be happening.
Unread 28-03-2010, 13:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Our 6" plaction wheels started to exhibit cracking in the spokes almost immediately after we started going over bumps at competition weight.
Mistakenly, I ignored the crack in our competition robot wheel, as it was only on one half of one spoke. In semifinal match 1 at the Seattle regional, the wheel shattered into three pieces, splitting at each of the three bolts we were using to attach the drive sprocket.
We were able to swap in a wheel after using our time out and run semifinal 2, though because it was our front wheel, we couldn't make it over the bumps. We ran chain again before the finals and were back in full working order.
As mentioned earlier in this thread, we'd now recommend that all teams use all 6 bolt holes on these wheels.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
  #15   Spotlight this post!
Unread 28-03-2010, 16:50
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
It seems like everyone is using the Andymark wheels with the standard 1" wide tread, but did anyone besides teams 3193 and 48 use PVC spacers to widen the 6"-diameter wheels to 2"? We had success with them using black nitrile treads from McMaster in our 8-wheel drive, but we too had issues with the tread coming off when we tried using staples like the original AM treads. Two 1/8" rivets (1/2" long) drilled into the PVC spacer worked great.
However, we found another issue: when mounting sprockets, you have to watch how hard you tighten the bolts on the hubs, as there is no support between the hubs because of the spacer. We found a couple cracked spokes, and we found one wheel had all six spokes one one side broken through after our last quarter-final match in Cleveland. If...I mean when we use these again, we'll definitely look to add spacers at the center of the wheel so that the hubs are not squeezed and stress isn't transferred to the spokes.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Plaction and Omni wheels Edoc'sil Technical Discussion 7 21-02-2010 12:20
AndyMark Plaction Wheels Diserasta Technical Discussion 1 17-01-2010 22:20
Plaction Wheels : 250 Spacers/Review Ice Berg General Forum 2 17-01-2010 11:26
AndyMark Wheels Andy Grady Inventor 2 05-02-2007 16:49
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
