Go to Post I think it's important to keep FIRST's most important award as the top point getter [in Fantasy FIRST]. It's help reinforce that the Chairman's award, Engineering Inspiration and Woodie Flowers award are actually important and FIRST is about more than just the robots. - Koko Ed [more]
Unread 23-03-2010, 08:54
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
LEDs on Robot
Hi,
Is is permitted to have additional LEDs on the robot? If so, which set of outputs are we allowed to use? We switch our robots front and back assignments by inverting our controls and we would like to use the LEDs to indicate which is the front/back.
Thanks,
windell
Unread 23-03-2010, 09:20
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: LEDs on Robot
They are legal on the robot, as long as it does not affect the outcome or gameplay of the other teams. Mainly, is it too distracting for others, and will it affect the camera systems are the main two questions you should think about.
I am not sure what the proper way is, but we recently added some similar lights to an old bot at the shop to do some driver testing with a modified HUD. We simply ran them from a 20Amp Breaker to a Spike Relay. Then tied it to the cRIO with a PWM. I know this is the method for custom circuits that are non-functional*, but I would assume the same would apply functional lights.
Someone please correct me if I am wrong.
-Tim
*By non-functional, I mean decoration only
Unread 23-03-2010, 09:21
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: LEDs on Robot
There are no rules directly against this, as long as it dosen't interfere with anyone's vision system, or is powered by something other than a 20-amp breaker (directly or indirectly). You can use DIO pins, Relay ports (they're actually 2 digital outputs), or Spikes to drive the lights. We use a few 12v automotive light bars (around 12" long) to indicate important things, and drive them with Spikes. You need 1 spike for 2 channels, although low-amperage lights can be ganged up on a single channel. You would probably have one channel for front and another for rear.
Kettering Motorsports
Unread 23-03-2010, 13:56
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
Team Role: Mechanical
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
Re: LEDs on Robot
We have them on ours (red LED underglow) and we had no problems passing inspection.
Rob Self-
Cyberhawks Team 706
Hartland, WI
Our breakaway bot in action (13-3-1): Team 706 in action
Unread 23-03-2010, 14:53
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
Team Role: Coach
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: LEDs on Robot
Last year at UTC, team 230 had the most massive lights and they passed inspection. They were like neon lights. Lets just say I was happy not to be in a match with them.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 23-03-2010, 22:22
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: LEDs on Robot
As others have said, yes, they are legal as long as they are not going to interfere with other robots vision systems. This year that's less of a concern since the vision recognition targets are not lighted, or green.
The best way to do what you want to do is to connect the additional leds to spike relays so that you can turn on the ones you want in a given configuration. The important thing to remember is that if you are building your own led strings that they will be powered by 12 volts when you are doing your current limiting resistor calculation.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
LEDs RMiller Rules/Strategy 1 31-01-2009 02:47
OI LEDs B_Dubbs Programming 4 13-02-2008 21:35
OI Robot Feedback LEDs flashing Sirius Technical Discussion 4 10-11-2007 14:10
LEDs on CMUCam JJMax7 Programming 2 03-02-2006 12:28
Feedback LEDs on OI bstempi Programming 1 22-02-2004 21:18
